sierra shims?
Old Mar 22, 2009 | 04:11 PM
crazydan's Avatar
crazydan
Default sierra shims?
ive lowerd my sierra 35 mm and i have the usuall rear toe and camber isues
does anyone no were i can shims made or are the avalable to buy?
help needid cause ive done 3000 miles and my rear tyers are f*****
thank's Dan
Old Mar 22, 2009 | 04:25 PM
Retro Al's Avatar
Retro Al
RWD IS KING
mike rainbird
Old Mar 22, 2009 | 08:03 PM
Mike r sells some shims about £10, depending on where you put them, it will adjust toe, or camber, if you want, but I ran 3 1/2 degrees camber on my last sierra with totally normal tyre wear, so I'd take some of the inherrant toe out away.
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
