MPG on a 300BHP Saff 4x4?
Old Dec 1, 2004 | 12:06 PM
Daveyraveygravy's Avatar
Daveyraveygravy
Default MPG on a 300BHP Saff 4x4?
What sort of milage would you expect to get from the above state of tune?
At the moment i'm getting about 180 miles to £42, with semi hard driving, going up and down the A13 every day at 70.........................ish
Thats at stage 1 running about 270ish BHP. I do alot of idleing where i warm it up and cool it down though.
Is that about right?
I've got the stuff to do it i.e Greens, 3 Bar MAP and Chip, but i haven't got the breather kit on yet. Should i get that first?
Thanks,
Dave
Old Dec 1, 2004 | 12:09 PM
JamesH's Avatar
JamesH
Get it lived mapped you should see around 30+MPG IIRC
Old Dec 1, 2004 | 01:07 PM
AlexF's Avatar
AlexF
thats about 50 litre of fuel...
or 11 gallons...
so
16mpg very
Old Dec 1, 2004 | 01:47 PM
R4N SS's Avatar
R4N SS
180 miles on a 42 quid on stage 1
I think i get that on my 400bhp engine
my last engine stage 3 used to do average about 230 miles to a tank.
Old Dec 1, 2004 | 01:53 PM
Stu @ M Developments's Avatar
PassionFords Creator
On the motorway at 85mph average mine does just under 340miles on £40
Old Dec 1, 2004 | 02:18 PM
Spiky's Avatar
Spiky
chip from stu, setup by a rolling road ( might add, not the best )
but i still got 300 from £40ish crusing... on stage 3, t34, greens
even at 130+ i still managed 200-250
edited to say, rolling road not the best, the chip was top
Old Dec 1, 2004 | 02:45 PM
Rhys's Avatar
Rhys
thats terrible on Stage 1!!!!!
mine does that on 400bhp on and of driving hard
Old Dec 1, 2004 | 02:47 PM
R4N SS's Avatar
R4N SS
i have never seen 300 miles on a full tank in the cossie
Old Dec 1, 2004 | 02:48 PM
R4N SS's Avatar
R4N SS
come to think of it - i only just manage to get 300 miles on my saff 2.0i ghia which is all standard, and that is mostly taking it easy.
But then i could be down to my driving style and big heavy feet
Old Dec 1, 2004 | 03:40 PM
Ginge !'s Avatar
Ginge !
just finding my feet
get a chip off stu and drive to stus and get him to set it up, but if ya want the best economy then get a live map setup, trust me thats the best option
bit at the moment incase ya not aware im very happy with my chip and set up by msd, also the price was very very good
Old Dec 1, 2004 | 03:47 PM
R4N SS's Avatar
R4N SS
ginge - was urs a live map then or an off the shelf chip?
Old Dec 1, 2004 | 04:01 PM
Ginge !'s Avatar
Ginge !
of the shel chip that stu very very very kindly tweeked to my fooked up engine spec
cant recomend him anymore
there was only 1 complaint i have
why the foooook does he have to be based in blackpool, talk about end of the world
think he should move to london, be alot more convinient and jims constant car problems would keep him in business
Old Dec 1, 2004 | 05:16 PM
CosKev3's Avatar
CosKev3
My 4x4 was no diffrent on fuel going from stg1 to greens set up on average
Obviously used more when booting it
Best I got was 28 mpg at 80-90mph motorway run,worked out 300 miles on £40 With 4 people in car.
Would do 100 miles on £20 short trips
Old Dec 1, 2004 | 07:18 PM
You still happy Ginge? I thought you were blaming me for your near death experience the other night.. roflol
Old Dec 2, 2004 | 12:13 AM
Daveyraveygravy
Thanks for the replies guys, just want to know. When a car is 'set up' i understand that the boost is measured with a boost gauge and set up witht the actuator, but how do you set the fueling up properly? Do you check the fuel pressure with a gauge and set it using the regulator or is it a laptop job, up this a bit lower that a bit?
Is there anything else you do when 'setting the car up?'
Ta,
Dave
Old Dec 2, 2004 | 07:31 AM
smokey's Avatar
smokey
Are 2-door fuel tanks bigger than a Saph 4x4 tank?
Old Dec 2, 2004 | 07:53 AM
Ta,
Dave
fuelling settings are first done at the fuel regulator by ensuring that is working and set perfectly to standard and the rising rate is correct.
Then the co is adjusted.
Then the car is driven with a wideband air fuel ratio monitor fitted to the car and teh fuel settings on cruise, part throttle and load are checked.
Hope this helps.
Old Dec 2, 2004 | 10:02 AM
Daveyraveygravy
Pukka, thanks stu.
My CO was running at 6%! (The MOT man didn't like me, he said i was creating my very own hole in the ozone layer!! )
I've since had it lowered to 4%, is this still to high?
I did have my fueling checked a year or so ago, does it need 'tweaking' on a more regular basis? I think it was 2bar on idle and went up to 2.5 or is it 3.5bar on boost.
Old Dec 2, 2004 | 10:43 AM
Cawood's Avatar
Cawood
eh?!?! i wouldn't have thought you lot would have got any where near that sort of MPG, i only drive a 200bhp RST and get 150 miles to £35!!!!
must have a hole in the tank or need to change my driving style!
Old Dec 2, 2004 | 10:49 AM
R4N SS's Avatar
R4N SS
3dr tank is 60 litres as are saph tanks - but someone correct me if the 4x4 ones are not 60 litres.
Cawood - finally a car that has worse fuel consumption than mine u could be driving a cossie with the amount u sepnd on fuel and still have money left over
Old Dec 2, 2004 | 10:55 AM
Demondave's Avatar
Demondave
My stage 4 saff does about 230 miles to a tank
Old Dec 2, 2004 | 10:56 AM
Cawood's Avatar
Cawood
tell me bout it ran, thinking cossie now, cheaper to run
Old Dec 2, 2004 | 11:36 AM
Daveyraveygravy
Cawood, Yeah ok the petrol cost may be cheaper but i'd stick with your RST cos when a cossie goes wrong it usually costs more.......... a lot more!
Old Dec 2, 2004 | 11:44 AM
Pukka, thanks Stu.
On a stage 1?
Id be wanting her at sub 2%mate on non lambda controlled and 0.3 - 0.5% with lambda control.
Fuel pressure is 3.5bar idle and 1:1 rising ratio
Old Dec 2, 2004 | 11:53 AM
Daveyraveygravy
Oh you think that could be why my car is driving like a dog when it's cold then Stu? It also feels like it misses when you let off, and when you plant it, it hesitates/misses for a split second then goes and feels fine untill you let off again.
If i rev the car standing still past 2k rpm then slowly let it down to 2k rpm and hold it there it feels like its missing.
Could it be coked up and need a thrashing or is it more likely that something is not right?
I'm a bit cautious when booting it now as i don't want to blolw a piston!
Old Dec 2, 2004 | 11:54 AM
Jim Galbally's Avatar
Jim Galbally
stop complaining youre getting better MPG than me
altho i did manage better than normal fuel consumption lastnight and that was ***NOTE STU STOP READING HERE*** driving flat out most of the time ***STU START READING HERE***
i fookin love closed loop too... can get 300+ miles to a tank on the motorway
Old Dec 2, 2004 | 11:55 AM
Daveyraveygravy
@ Jim!
Old Dec 2, 2004 | 05:28 PM
Youve definately got problems mate...
Old Dec 2, 2004 | 06:40 PM
Ginge !'s Avatar
Ginge !
book it in to stu and have a fun day in blackpool
deffo happy with the results
well intill me car broke
Old Dec 2, 2004 | 06:52 PM
steviep's Avatar
steviep
my motors definately got issues then, I get 60 miles to £15
Old Dec 2, 2004 | 08:11 PM
Old Dec 2, 2004 | 08:12 PM
steviep's Avatar
steviep
it's completely standard as well
Old Dec 2, 2004 | 08:33 PM
Old Dec 2, 2004 | 08:44 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
mine can be quite juicy for a stage1 on boost
his car does sound really rich stu,well it did to me last night
Old Dec 2, 2004 | 08:51 PM
Ginge !'s Avatar
Ginge !
sound dont ya mean the smell, small animals dropping dead on the side of the road as ya cruise by
Old Dec 2, 2004 | 09:21 PM
saff_cossie's Avatar
saff_cossie
Thats what I get roughly on a stage 1 as well. I know it is over fuelling massively though. At idle it has a wisp of black smoke every so often.
Stu - Is the adjusting you mention above, something I could do or does it have to go to a tuner?
Sorry to hijack!
Old Dec 2, 2004 | 11:56 PM
Daveyraveygravy
his car does sound really rich Stu,well it did to me last night
Funny you said that pops, my friend mentioned that the other day, but he said it 'smelt' rich, how can it 'sound' rich?
It doesn't throw out any smoke though, would have thought it would if it was running rich
Old Dec 3, 2004 | 12:12 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Spikey- Where did you go in the end? Powerstation wasnt it? Or Interpro?
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
