advice please
Old Mar 21, 2009 | 04:09 PM
dangerousbrian's Avatar
dangerousbrian
Default advice please
just about got my car sorted finally and will be going to get a setup as its been apart then put back together..anyway, what i want to know is there anything i could do/check to make sure it runs as good as possible until it gets sorted by a pro? i have set the ignition timing as accurate as possible with a timing gun (crap but best i had)..i know the tps will need adjusting? can i do this at home? anything else to look at that can be easily sorted or adjusted? thanks in advance people
Old Mar 21, 2009 | 05:12 PM
robj20's Avatar
robj20
They charge by the hour so just get 2 hours on the rollers and let them do it.
Old Mar 21, 2009 | 05:44 PM
dangerousbrian
thats what im planning to do, but want to get it as best i can before then as i will most probably have to drive it there...approx 150 miles to get there
Old Mar 21, 2009 | 06:04 PM
Chopshop85's Avatar
Chopshop85
as long as it moves i wouldnt worry about it. cos anything you do they might undo/change on the rollers.
Old Mar 22, 2009 | 01:07 AM
ROB7656's Avatar
ROB7656
just drive off boost if it runs
Old Mar 22, 2009 | 10:53 AM
Karlos G's Avatar
Karlos G
Balls Deep!
+1
Old Mar 22, 2009 | 10:56 AM
BigErn's Avatar
BigErn
as long as it starts and runs mate, Id be trailering it to wherever.
Old Mar 22, 2009 | 11:08 AM
dangerousbrian
ern.. thought bout getting a trailor from your yard..might struggle to find summat pull the trailor tho
Old Mar 22, 2009 | 11:09 AM
BigErn's Avatar
BigErn
borrow gaz's van
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
