Timing help
Old Mar 18, 2009 | 07:29 PM
smerth54's Avatar
smerth54
Default Timing help
is there another way to time up a car ive got the head off so couldnt i just make sure the first piston was at the top or bottom where ever it needs to be cos ive been tryin to get the bottom pulley off 4 ages now and it wont budge tried everything i can think of. help please
oh its on a fiesta rs turbo
thanks rich
Old Mar 18, 2009 | 07:33 PM
babscossie's Avatar
babscossie
take out the starter motor and lock the flywheel with a screwdriver/prybar. then you'll be able to undo the bottom pulley bolt easier.
Old Mar 18, 2009 | 07:43 PM
fraser9764's Avatar
fraser9764
buy or borrow a decent impact gun, best tool you will ever buy
Old Mar 18, 2009 | 08:12 PM
smerth54's Avatar
smerth54
yea i done that with a screw driver and it wouldnt budge.
but can u time it up another way?
Old Mar 18, 2009 | 08:53 PM
B16CVH's Avatar
B16CVH
Drop a DTI on No 1 piston and there you go!
Old Mar 18, 2009 | 10:42 PM
smerth54's Avatar
smerth54
a dti?
Old Mar 18, 2009 | 10:51 PM
B16CVH's Avatar
B16CVH
One of these
http://www.toolspot.co.uk/product/dti-gauge-in-box
Probably a bit overkill to be honest, what is it you are actually doing seeing as you have the head off?
Old Mar 18, 2009 | 10:58 PM
smerth54's Avatar
smerth54
i changed the head gasket and the vavle stem oils seals, cant i do this with out one?
Old Mar 18, 2009 | 11:00 PM
Dan1281's Avatar
Dan1281
lock the crank with a screwdriver, put a spanner or a t-bar on the pulley bolt and hit it with a hammer, when you shock things they undo loads easier
Old Mar 18, 2009 | 11:09 PM
smerth54's Avatar
smerth54
yea but wont the screwdriver fall out?
Old Mar 18, 2009 | 11:16 PM
rst in breaking's Avatar
rst in breaking
buy a proper flywheel locking tool then, bolts in place of your starter motor
Old Mar 18, 2009 | 11:18 PM
smerth54's Avatar
smerth54
they expensive
Old Mar 18, 2009 | 11:23 PM
Dan1281's Avatar
Dan1281
get someone else to hold it, and a decent sized pry-bar is better than a screw driver, where theres a will theres a way haha, dont let it bear you, i cut a wishbone off a golf today with a 9 inch grinder because the captive nut spun, theres allways a way
Old Mar 18, 2009 | 11:28 PM
smerth54's Avatar
smerth54
haha i cant b cuttin things lol, k ill habve another go 2moz, but couldnt i just lower the first psiton down would that b it? save all this hassle
Old Mar 18, 2009 | 11:46 PM
westus1's Avatar
westus1
as long as the cam times up to tdc then
just turn engine till pistons 1+4 are right at the very top
what engine/car is it?
Old Mar 18, 2009 | 11:47 PM
smerth54's Avatar
smerth54
itas a fiesta rs turbo cvh engine
Old Mar 19, 2009 | 12:04 AM
smerth54's Avatar
smerth54
so if i move the pistons 1 and 4 up to the top then put the head back on and time the top up it should b spot on
Old Mar 19, 2009 | 12:10 AM
Dan1281's Avatar
Dan1281
you can put the pistons at TDC(ish) when the head is on by putting a screwdriver down the plug hole and feeling for when its at the top
Old Mar 19, 2009 | 12:11 AM
smerth54's Avatar
smerth54
which plug hole? plus the heads off atm so, but basically to get it perfect i need get that pulley off
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
