Clutch.. CP2000-8 or CP2000-35 for 200-250 bhp?
Old Mar 17, 2009 | 11:05 PM
Antti O's Avatar
Antti O
Default Clutch.. CP2000-8 or CP2000-35 for 200-250 bhp?
Yep. simple as that.
I am building new 1600cvh turbo motor and i need uprated clutch. I ve been thinking ap racing organic set. -8 or -35? I will use 15-18 psi of boost (1.0-1.3bar)
Do i really need uprated quadrant kit, if i buy -8 clutch kit.
How about pedal feel? I have bit fucked left knee because of past accident so i cannot drive car with too hard clutch.
Cheers Antti-Ville
Old Mar 17, 2009 | 11:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I have CP2000-8, pedal is much heavier than standard and yes i had to do quadrant upgrade or it would not dissengage fully.
Old Mar 18, 2009 | 08:00 AM
RST_Rob's Avatar
RST_Rob
Just to throw another clutch in there i have the CP5354-15 clutch with a standard ford clutch cover to keep the soft pedal and works a treat even with 245lb-ft of torque
Old Mar 18, 2009 | 08:05 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
AP 4 paddle.. std cover.. win.
Old Mar 18, 2009 | 09:11 AM
Antti O's Avatar
Antti O
I had std cover with paddle clutch in my ex rst and it was light to use but it squeeks and did wear flywheel.
I think i choose ap-racing cp2000-8 and test how much torque it would take, i do not have monster torque because i have only 1600cc engine. If someone could describe how stiff the cp2000-8 kit is to use with uprated quadrant? I think the RST original clutch is very light to use, almoust girly clutch so i can live with bit harder pedal feel.
Old Mar 18, 2009 | 04:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As i said it is very heavy/stiff but you get used to it.
Old Mar 18, 2009 | 06:08 PM
Antti O's Avatar
Antti O
Do you have these quadrant part numbers still in memory? Some information that burton website do have wrong part numbers.
Old Mar 18, 2009 | 06:38 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The AP website has the part numbers and a guide how to fit it! I will look for you now.......
Old Mar 18, 2009 | 06:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
See here http://www.apracing.com/info/info.as...difications_90
Old Mar 18, 2009 | 07:28 PM
Antti O's Avatar
Antti O
Nice. I emailed to ford about prices of those parts.
Many thanks karlos!
Old Mar 18, 2009 | 09:34 PM
makaveli96's Avatar
makaveli96
If your running that sort of power I think a 4 paddle will be better in the long run as it will handle more power and last longer, as for the clutch the Helix 4 paddle clutch is just as good as the AP but is more driveable and softer than the AP that was what I was told by two performance garages I’m getting my Helix clutch fitted this Friday at Jamsport so I will let you know what’s it like.
Old Mar 18, 2009 | 09:41 PM
Rick's Avatar
Rick
Paddle's will NOT last longer for stop start!
Old Mar 18, 2009 | 11:20 PM
rstdave's Avatar
rstdave
I have the cp200-35 ap clutch and tbh can't fault it. I'm not running mega power (245bhp/230ft pounds) but it has taken everything thrown at it so far and it does get used hard, track, qtr mile etc. As it uses an organic plate it's not juddery like the paddles, and wouldn't say it's ridiculously heavy imo. From what i've been told it's the cover that makes all the difference in terms of how much torque they will take.
Old Mar 19, 2009 | 05:50 PM
Antti O's Avatar
Antti O
I will order cp2000-8 clutch kit today, lets see how it goes.
Thanks for all
Old Mar 19, 2009 | 10:58 PM
Karlos G's Avatar
Karlos G
Balls Deep!
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Marv888
Sep 26, 2015 03:44 PM
