OE switch/button printing - can anyone do it?
Old Mar 17, 2009 | 10:40 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Default OE switch/button printing - can anyone do it?
Looking at the labelling on these 4 buttons/switches - would it be possible to have the writing ammended/changed properly to look factory?
Any info appreciated
Old Mar 17, 2009 | 11:04 PM
Its Dave's Avatar
Its Dave
How about using letraset with a bit of varnish
Old Mar 17, 2009 | 11:11 PM
Big Will_'s Avatar
Big Will_
Tis an option - just wondered if there was a printing process that could do it.*
*Quickly/Easily/Cheaply
Old Mar 17, 2009 | 11:18 PM
Cam's Avatar
Cam
Originally Posted by Will @ M Developments
*Quickly
YES!
/Easily
TES!!
/Cheaply
NO
A screenprintung firm could do it but as a one off 10 to 20 quid a button
Old Mar 17, 2009 | 11:19 PM
cjwood555's Avatar
cjwood555
To get it properly silk-screened won't be particularly cheap - I know of a supplier who can do it for Ł100 minimum charge, which I think that would qualify for.
The other option (which may be how it's been done by the oem) is to have the new legend laser/mechanically engraved/embossed to e.g. 0.25mm, then paint it in and wipe away any excess. This should be cheaper as anywhere with CNC mill or laser cutting facilities could do it.
Chris
Old Mar 17, 2009 | 11:20 PM
Big Will_'s Avatar
Big Will_
Cheers for the info Cam...
If it was Ł20 for a factory finish job - i'd probably do it...
Ł40 suddenly seems a LOT of money though
Old Mar 17, 2009 | 11:21 PM
Big Will_'s Avatar
Big Will_
Chris - I did wonder about having it laser etched! Now all i need is someone with a laser etcher...
Old Mar 17, 2009 | 11:25 PM
Cam's Avatar
Cam
That was per button as well
I had an Alpine 7909 stereo facia custom screenprinted...in 1988 and it cost me a bottle of vodka and an eighth of special Morrocan herb extract..lol
Old Mar 17, 2009 | 11:27 PM
Cam's Avatar
Cam
Engraving then painting would be cheapest option imo
Old Mar 17, 2009 | 11:30 PM
cjwood555's Avatar
cjwood555
Try a watch/jewellery shop for mechanical engraving, if you don't need fancy graphics etc....
Or give CEL in Telford a ring
Old Mar 17, 2009 | 11:37 PM
Big Will_'s Avatar
Big Will_
Basically i've got a blank 2 switch panel in my dash at the moment, i'm wanting to get something like from the above photo and modify the 2 switches to control my nitrous arming swith and bottle heater
So would only be after a bit of lettering to indicate which is which
Old Mar 17, 2009 | 11:41 PM
Cam's Avatar
Cam
letraset/laquer or mechanical engraving paint will be your best/cheapest options
Old Mar 18, 2009 | 07:39 AM
bunjeeman's Avatar
bunjeeman
A connoisseur I see...... you still have your 7909?
Old Mar 18, 2009 | 09:57 AM
Cam's Avatar
Cam
Yes still got it and still works/sounds perfect
Old Mar 18, 2009 | 11:01 AM
St3V3_C's Avatar
St3V3_C
As the white part of the symbol lights up (I think LOL) it will be a bit more difficult...
Old Mar 18, 2009 | 12:16 PM
Twellsie's Avatar
Twellsie
we do similar on aircraft switch gear, the plastic we use is effectivelly clear perspex with a matt black over it then engrave at a few microns to show the white/clear underneath
Old Mar 18, 2009 | 01:05 PM
bunjeeman's Avatar
bunjeeman
sorry to be off topic, I have one too! Always wanted to find a spare! lol
Old Mar 18, 2009 | 01:39 PM
cjwood555's Avatar
cjwood555
Will, bear in mind that the switches are non-latching as the systems are controlled via the GEM in a focus. You will therefore need either a latching relay or an electronic latch circuit which would take up less space (can build you one if you need it).
Old Mar 18, 2009 | 02:12 PM
daviddunlop83's Avatar
daviddunlop83
I think the wee circle is the only part lights up. I should remember this i had a ST170 for 3 years lol.
Old Mar 18, 2009 | 04:01 PM
St3V3_C's Avatar
St3V3_C
Sorry, I mean with sidelights, not to show the button has been pressed.
Old Mar 18, 2009 | 04:15 PM
RANJ's Avatar
RANJ
lol still have my 7909 and 7638r (twiddler)
tankybaby66
Feb 6, 2016 02:24 PM
3drRich
Sep 13, 2015 07:32 PM
marky_g
Feb 3, 2005 07:53 PM
TIFF
14
Dec 26, 2004 11:41 PM
