Pectel T6 E.C.U
Any one out there build a big spec engine this is a must ,T6 is used on WRC escorts,rallycross and loads of other race stuff !!!! data logs and much much more have a search about and see!!!!!
I get what your saying but the setup cost should be taken out of the picture if you ask me...as nobody is going to have the same spec as you did when it was mapped. Every car is different especially when talking T6 ecus. It's not the same as a stage 1 or 3 chip where you pretty much know its going to work... you have to set the t6 and all sensors up to the specifics and have it checked over and mapped....regardless of what map is already in it.
I am seriously interested in this, your inital price was way too high for me so it put me off...you're right if it comes with the sensors and loom then its worth a few hundred more. I'm on a 4 inj manifold so would need work there possibly.
If you are willing to come down on price I may be interested. Please pm me your rock bottom price bearing in mind what people are saying here
Dan
Dan
That's not a bad price guys. Its a T6200 that's known and configured to work on a YB for a start. It will run 4 injectors with no mods, that's just a software setting.
I cant remember even seeing a T6 2000 for sale or anywhere else recently.
It soon adds up and you have everything need there.....Loom, plenty of sensors, pulleys, dizzy, other than a remap to suit your engine and if it has traction that's a Ł400 optional extra on a T6.
Can be unlocked easy and pretty cheap by Pectel.
Good luck with your sale.
From: brum/shropshire drives:- frst / escort cossie
great ecu this not trying to spam here either BUT s/h its not worth what your after my Autronic SM4 with loom etc only cost me 2k new! plus the existing map is useless to the next owner anyway!!!! very good ecu T6 BUT people pay for the name with pectel theres alot of other ecu's on the market that do the same for less IMO... as said for no messers sale i'd lower it to 2k posted and someone will bite your hand off...
HTH Ad
HTH Ad
HTH Ad
HTH Ad
The existing map configured for those sensors and a YB is actually a REALLY good start point for someone as a base trust me and would need minimum adjustment to get a car running as a pose to starting with an unknown locked ECU with no base map.
i was trying to help nicely not like you posted was it?? if its such a bargain you buy it!? and if your so clever you'd realise that each tuner would map differently so really a base is a base so its doing no extra favours... all i have to say... good luck with sale weller apologies if my comments upset you trying to help... polly really not bothered what you have to say...
I already run a T62000 on my YB mate so unlike most who choose to comment on here actually have the experience to know about this stuff and how expensive it would be to buy all that kit.
Its very rare to see such an opportunity to buy everything you need with the ECU in one place job done hence why I think its not a bad deal.
it seams that un less parts are cheep they dont sell these days mate
t6 ecu"s like this i have seen go for 1200
when i baught mine it was new 2.5k for it there was no second hand ones for sale at the time
thanks steven..
thanks steven..
I think if you say put the ECU at Ł1,000- Ł1,500 you would have no problems with shifting it but you are left with the loom and sensors to shift which may be hard to sell.
DixieTheKid
11
Jun 6, 2020 11:20 AM
muz
Aug 16, 2015 12:57 PM
