brake problems
Old Mar 10, 2009 | 07:07 PM
B1G_RST's Avatar
B1G_RST
Default brake problems
been a while since ive posted on here,, anyways put a whole new brake setup on my rs, hi spec 4 pot fronts 280mm discks, and a cossie rear disc conv, removed the abs and ran new pipes to the T-joints, fiteed a brand new master cylinder last year,
put in for mot today(which it passed first time ) although the brakes are rather shite and on the brake test the rears seemed very poor as did the front, i have run braided pipes also,,
bled the sytem twice now and still seems soft pedal and not a £1000 pounds worth of braking power, anyone shed some light on my problem?
Old Mar 10, 2009 | 07:28 PM
macrs's Avatar
macrs
Do you still have the load compensators on the back?? If they're sticky or not set up correctly that should account for poor rear braking?? I know it was on mine at its mot last year.
As for your fronts, I don't have the knowledge on four pots but I believe they're a bit of a pig to bleed??
Or could the master cylinder be drawing air??
I say this as I removed my ABS last year, re-piped the system and fitted cossie discs and calipers as well as fitting a new seal kit to the master cylinder. Left the drums on the back, set the rear compensators up after cleaning them, flushed and bled the whole system and my brakes are spot on now.
Hope this sheds some light for you!
Old Mar 10, 2009 | 07:39 PM
project rs's Avatar
project rs
probably got air stuck in rears as they sit at the wrong angle when bolted in place on rst , you need to unbolt one of the retaining bolts and swivel the rear caliper so the bleed nipple is upper most so the air can rise to top and out
Old Mar 10, 2009 | 08:27 PM
B1G_RST's Avatar
B1G_RST
cheers mate
Old Mar 10, 2009 | 08:28 PM
B1G_RST's Avatar
B1G_RST
never thot of that mate,, ill try and move the caliper to get the nipple to the highest point cheers
Old Mar 10, 2009 | 09:02 PM
boost monster's Avatar
boost monster
Try bleeding with pressurised master cylinder rather than "pumping" the brake pedal this works better for me.
Old Mar 11, 2009 | 07:21 AM
B1G_RST's Avatar
B1G_RST
ive tryed using a sooker thingy, is this a somthing that screws onto the resisvior ? if so where can i get one ? cheers
Old Mar 11, 2009 | 09:32 AM
macrs's Avatar
macrs
Here's a link to the eazi bleed thingy... forgot to mention this is what I used to flush my whole system.... you wouldn't believe the crap that was flushed out of the rear of the system!
http://www.machinemart.co.uk/shop/pr...sfer-equipment
Old Mar 11, 2009 | 12:30 PM
B16CVH's Avatar
B16CVH
I had to do this on mine, was a right bastard, had to unbolt the caliper completeley and lift it just outside the wheelarch, you must make sure however that you have the disc or something the same thickness between the pads to stop them moving inwards.
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
