adjusting boost, cossie
Old Nov 29, 2004 | 10:32 PM
darren.cudd's Avatar
darren.cudd
Default adjusting boost, cossie
ok really really dumb question and im expecting abuse for this post
but which bloody way should i be turning the actuator bar to lower the boost?
had a quick go on sunday, i thought to lower the boost you should make the bar longer so that the wastegate opens sooner?
surely making it shorter so you have to stretch it over the wastegate arm means its guna hold closed for longer?
but even with it so long that it only just holds the gate closed it was spiking up near 2bar (foot came off throttle very quickly )
boost was fine before but had to take the actuator off to do something
am i just beeing a thick inbread?
any HELP is appreciated
Old Nov 29, 2004 | 10:44 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Shorter. But only a little at a time.
Old Nov 29, 2004 | 10:59 PM
darren.cudd
what, shorter will make it boost lower?
am i really being that thick?
Old Nov 29, 2004 | 11:03 PM
Sketch's Avatar
Sketch
Shortening the actuator rod will increase boost!
Old Nov 29, 2004 | 11:08 PM
darren.cudd
thats what i thought but even with the wastegate slightly open at no boost its still hitting 2 bar when it come on
Old Nov 29, 2004 | 11:10 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
well rejet the amal then
Old Nov 29, 2004 | 11:15 PM
darren.cudd
amal aint connected to the ecu pops, got it on a manual switch for high/low boost and that wasnt turned on
Old Nov 30, 2004 | 09:05 AM
darren.cudd
anyone else give me a definate answer as the 2 abouve are different
Old Nov 30, 2004 | 09:10 AM
Stu @ M Developments's Avatar
PassionFords Creator
Lengthening the rod will lower the boost.
It must not be lengthened to less than 3mm of preload under any circumstances.
Old Nov 30, 2004 | 09:15 AM
zvhturbo's Avatar
zvhturbo
Can you explain that in more "plain english" please
Old Nov 30, 2004 | 09:20 AM
darren.cudd
ok thanks stu, just dont get whats going on with the bloody thing boost was fine before, but had to take the actuator off to do another job, didnt have much time but tried it from aprox 4mm preload to 0 and was still getting +1.8 bar of boost, even though at 0 it was taking bloody ages to boost as it was obviosly leaking loads of air
what happens when you go under 3mm then? apart from it not boosting
btw, apart from me not being able to set the boost the rest of the map seems really good (i set the co at 3% just till i can get it double checked on a rr session, this will be ok wont it? )
CabrioTurbo's Avatar
CabrioTurbo
drren if your using the amal valve.. are you sure you havent reconected the pipes the wrong way round and hence creating 'unlimited' boost?
Old Nov 30, 2004 | 09:22 AM
darren.cudd
hmmm pretty sure anyone want to list the way it should be installed so i can double check it at the weekend
Old Nov 30, 2004 | 09:30 AM
3% will be fine if youve sorted your 900Psi fuel pressure out first?
Amal connections:
W = Wastageate actuator
C = Compressor housing
R = Return.
I bet youve put the actuator pipe onto R
As for preload, do a search, theres some pretty large essays around on that subject already
Old Nov 30, 2004 | 09:33 AM
CabrioTurbo
Old Nov 30, 2004 | 09:34 AM
darren.cudd
Amal connections:
R = Return.
900psi? dont you mean 50
ok thanks stu, looking at that and from memory i think you guys may be right i think next sunday il just bypass the amal to get the thing set up (will put it back in once sorted )
Old Nov 30, 2004 | 09:39 AM
darren.cudd
oh and actually i dont know wre ive put c and r but im pretty sure i put w to waste as in waste air not needed so dump out the system
Old Nov 30, 2004 | 09:41 AM
** = More polite to a customer than:
Old Nov 30, 2004 | 09:45 AM
RichardPON's Avatar
RichardPON
FPMSL @ Stu
Old Nov 30, 2004 | 09:53 AM
darren.cudd
barstard, im making a chalange for jims title didnt you know think im in the lead at the moment
Old Nov 30, 2004 | 10:05 AM
The great thing is, if you had switched on your two stage boost, the boost would probably have gone down as you activated the R port your actuator is piped onto
Old Nov 30, 2004 | 10:06 AM
darren.cudd
i did try that actually and didnt seem to do shit
Old Nov 30, 2004 | 10:13 AM
Ahh.. but you say you backed off at 2.0 bar so how do you know you pussy? It may have been 2.9bar off and 2.4bar on
Old Nov 30, 2004 | 07:07 PM
darren.cudd
sorry i'll go be a man and try it then mate (new engine on order )
Old Nov 30, 2004 | 07:09 PM
Thats Better
Did i mention my chips have a 29psi boost limit?
Old Nov 30, 2004 | 08:28 PM
darren.cudd
Thats Better
no you didnt oh but that reminds me do they have a rev limiter on them? got one set up on the shift light but just curious really
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
