Rust treatment
Old Mar 9, 2009 | 04:16 PM
Barry R's Avatar
Barry R
Default Rust treatment
Whats the name of the rust treatment you paint on the rust that turns it back into metal
I remember reading about it in a thread ages ago
Old Mar 9, 2009 | 04:19 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
There's THIS stuff. I don't know if it's the same.
Old Mar 9, 2009 | 04:28 PM
It's Czech Mate's Avatar
It's Czech Mate
Sounds like the holy grail for Ford owners
I think you meant KURUST which just stabilises it and stops it spreading as quickly. Waste of time on a rusty motor, you need to get it all out unless you plan to botch it up to shift it on
Old Mar 9, 2009 | 04:36 PM
I love my fords but i hate the rust.
Old Mar 9, 2009 | 05:16 PM
scoooby slayer's Avatar
scoooby slayer
there crap mate. for a quick cheap fix just grind all the rust away then seal with paint, then filler and sand and aerosol. will stop it spreading any further as long as all rust is gone and is sealed before filler is used.
Old Mar 9, 2009 | 05:20 PM
RSandy's Avatar
RSandy
yup, 'kurust' type treatment does nothing to any rust more substantial than that caused by a very new stonechip. i put some on a tiny patch of rust in my bootfloor, all it did was turn it a delightful shade of purple until i overcoated it, and then spread like rust would normally
grind it right back until its all gone, or cut out and weld, and then etch primer coat it, only way to be sure its gone
Old Mar 9, 2009 | 06:25 PM
Barry R's Avatar
Barry R
The only bit is under the tail gate seal on the 3 door
The thread it was onwas paddys RS2K resto he said it turns it back to metal
Old Mar 9, 2009 | 06:30 PM
smithy rs2k's Avatar
smithy rs2k
i work in the commercial vehicle respray trade,we use loctite rust remedy does nothing what so ever ,shot blasting is the only way to kill it out
Old Mar 9, 2009 | 06:42 PM
BigErn's Avatar
BigErn
We used Kurust at work, top and bottom of it is its shit.
Cut out and replace with fresh metal or grind/shot blast it away.
Nov 1, 2015 06:53 PM
