Triton shower going hot/cold/hot/cold
Old Mar 9, 2009 | 10:50 AM
Markb_s1's Avatar
Markb_s1
Default Triton shower going hot/cold/hot/cold
Morning folks,
One of my tenants is complaining that the previously fine Triton electric shower (t80i?) is changing temperature from very cold to very hot at random points when it's in use.
Does anyone have any ideas why this would happen and what i can do to sort it? Don't really want to replace the unit if i can avoid it!
cheers
Old Mar 9, 2009 | 10:54 AM
dojj's Avatar
dojj
Resident Wrestling Legend
water pressure dropping and causing it to stop heating the water
assuming it's one of them that need a specific amount of water pressure before theyw ork right?
Old Mar 9, 2009 | 10:55 AM
R4N SS's Avatar
R4N SS
we used to have one of these showers and this was common
sorry not much help
Old Mar 9, 2009 | 10:56 AM
nilrem's Avatar
nilrem
STOP!... Carry on
is it a cold feed one? or has it got a hot feed and a cold feed? it could quite easily be water pressure if it has 2 feeds.
Old Mar 9, 2009 | 10:59 AM
stevenebm's Avatar
stevenebm
post whore
sure there is a filter that can be checked as it might not be getting the correct pressure of water mate.
Old Mar 9, 2009 | 11:02 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
inlet diaphragm split
Old Mar 9, 2009 | 11:04 AM
Markb_s1's Avatar
Markb_s1
thanks for the replies. It's a cold feed only, (good job too as the hot water pressure in the flat is crap anyway!)
I've not heard any mention from them about the cold water pressure decreasing so i'm guessing it's related to the shower itself.
anyone got any more specific ideas of what to cehck and how i do it?
pretty sure i can find an exploded diagram on the net somewhere as I did this before when the brain bung thing on the bottom was leaking.
Old Mar 9, 2009 | 11:05 AM
bud-weis's Avatar
bud-weis
Football Cwazy
ours did the same, was fixed under warranty...can't actually remember the fault though
it came with the house and i will replace it as its shite!
rsnissan's Avatar
rsnissan
make sure the head or anything after the outlet isnt blocked (with limescale maybe)
this can trip the internal temperarure switch to prevent scalding hence going hot then cold all the time.
Old Mar 9, 2009 | 11:31 AM
XRdodgybird's Avatar
XRdodgybird
Praise the XR!
I used to have problems like this in my old house and it was due to water pressure, someone only had to turn a tap on in the next street and we would be burned alive.
Old Mar 9, 2009 | 11:49 AM
RichieST's Avatar
RichieST
Yeah that used to happen on the shower at my mum and dads. It worked fine unless someone else in the house flushed the bog or turned a tap on or the washing machine was running!
Old Mar 9, 2009 | 11:50 AM
slowpoke's Avatar
slowpoke
http://www.youtube.com/watch?v=JWDYIWggpPY
sorry
Old Mar 9, 2009 | 03:48 PM
matstearn's Avatar
matstearn
hiya mate, we had the same thing with our Triton shower, same symptoms, was all fine until one day it started switching between cold and red hot. It is a cold water, gravity fed system, it turned out to be a thermostat switch in the unit. Replaced that and it has been fine ever since! Apparently not an uncommon fault according to the Triton helpline.
Old Mar 9, 2009 | 03:51 PM
jay man's Avatar
jay man
problem is the shower head needs to be cleaned the thermostat is clicking on/off because there is not enough flow
Old Mar 9, 2009 | 03:52 PM
Markb_s1's Avatar
Markb_s1
thanks for the advice everyone.
i'll check the head first then maybe give the helpline a bell.
Old Mar 9, 2009 | 05:23 PM
jameswrx's Avatar
jameswrx
I'd go with rsnissan on this one.
Also if the heater element is really scaled up it'll trip the unit to turn the heater off (if they are trying to run it hot) and it'll come out freezing until it calms down again.
Take the head off and the cover for the unit (with electric off!!) and run the shower fully cold, give the heater part a bang with your hand and see if it's full of scale (will literally start flowing out the hose)
You can remove the heater part and clean the scale out (all be self explanatory when you see it with the cover off) but you will need to disconnect the water into it (isolate stop cock obviously) and disconnect the wiring to get the guts of the shower out.
Old Nov 2, 2009 | 01:14 PM
smokey's Avatar
smokey
Never expected to be directed to Passionford when I googled the problem I had with my Triton shower.
Does anyone know how to take off the cover after removing the only screw located at the bottom?
Ta
Old Nov 2, 2009 | 01:37 PM
dingla rs's Avatar
dingla rs
by a new one
Old Nov 2, 2009 | 02:07 PM
R4N SS's Avatar
R4N SS
them showers are proper shit tho so yeah buy a new one
Old Nov 2, 2009 | 02:37 PM
Greggyboy's Avatar
Greggyboy
take it out and fit a mira they are generally alot better quality albeit a little more expensive
Old Nov 2, 2009 | 02:53 PM
R4N SS's Avatar
R4N SS
actually if its a rental then just fix the fault as that will be your cheapest option
Old Nov 2, 2009 | 02:57 PM
Markb_s1's Avatar
Markb_s1
did buy a new one in the end! this was a few months ago now!
smokey.. i think it was just a case of pulling at the thing with my one!
Old Nov 2, 2009 | 03:00 PM
R4N SS's Avatar
R4N SS
at least you wont kill the tenants
Old Nov 2, 2009 | 03:38 PM
Markb_s1's Avatar
Markb_s1
indeed... not much consolation when i think of the live outlet under my bath though!
Old Nov 5, 2009 | 10:06 AM
smokey's Avatar
smokey
Thanks Mark, I'll give it a good tug tonight.
Old Nov 5, 2009 | 12:30 PM
Markb_s1's Avatar
Markb_s1
too much info!!!!
Old Nov 5, 2009 | 02:15 PM
smokey's Avatar
smokey
Talking
Perhaps I should rephrase that.....lol
Davemurphy007
Motorcycle Chat & Sales
Aug 14, 2015 05:58 PM
Lee Reynolds
15
Jun 30, 2005 05:40 PM
