Ignition Timeing?
Old Nov 29, 2004 | 05:45 PM
Moonie's Avatar
Moonie
Default Ignition Timeing?
What should the ignition timeing be set to on an escort turbo with the following spec...
Stage 1 bayoo chip
Piper T2 cam (correctly timed up using vernier)
15psi
Ported n polished head
Low compression
Just rebuilt the engine and set the ignition timeing to standard (cant rememer the figure off the top of my head).
Any help appreciated, cheers
Old Nov 29, 2004 | 06:04 PM
ECU Monitor Enthusiast
Set it to standard timing but get it DET/FUEL checked before giving it large.
S1 engines/ecu 10 deg BTDC
S2 engines/ecu 12 deg BTDC
Old Nov 29, 2004 | 06:14 PM
Moonie's Avatar
Moonie
Old Dec 4, 2004 | 10:14 AM
Rick's Avatar
Rick
need it checked, as i dont know the advance curve on a bajoo chip.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
slammedorion
15
Nov 1, 2015 07:17 PM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
