Twin turbo zetec
Old Feb 22, 2004 | 08:47 PM
Default Twin turbo zetec
This may seem a strange post but what would be the advantages of a twin turbo'd zetec? would you run too small turbos or different size? and could say efi management cope or would aftermarket be a deffinate?
I only ask as i saw a twin turbo manifold advertised somewhere and not been technically minded could'nt see the advantages.
Rsssss
Old Feb 23, 2004 | 12:31 AM
EIL132's Avatar
EIL132
You'd need a helluva lot of engine work to take full advantage of that set up and no, standard management would not be ok!
Old Feb 23, 2004 | 01:12 AM
PJay's Avatar
PJay
Standard management would be a definate NO-NO but it could be done, can't see the pro's outweighing the cost though TBH
Old Feb 23, 2004 | 06:19 PM
The idea is to run two different sized turbos. Samll one for say 1800-3500 and a larger one to cover 3000+. You get low down response and top end power.
Saw a briefing paper at work this morning that said Vauxhall may produce a diesel with this kind of setup in the near future. I don't remeber the exact figures but it produced someting like 122hp/LITRE (froma diesel!!) and 500Nm of torque!
HTH.
Iain
Old Feb 25, 2004 | 05:40 PM
Don't know if anyone was interested, checked my figures and I had them slightly wrong Here's the text:
The 2005 Opel OPC Vectra GTS developed by the company's internal tuning group, Opel Performance Center (OPC), is expected to feature GM's first two-stage (or "register loaded") twin-turbo common rail diesel in a light duty vehicle. The result is a remarkable level of power and torque from a modest displacement. The new 1.9L inline 4-cylinder generates 212 hp (112 hp/L from a diesel!), and approximately 400 Nm (295 lb-ft) of torque from 1400-3600 rpm. The two-stage twin-turbo setup allows each turbo (one small, one larger) to contribute boost across the rpm range for optimum pressure charging. The low inertia of the small turbo permits rapid boosting below 1800 rpm, while the larger turbo contributes a high magnitude of boost above 3000 rpm. The rpm range between 1800-3000 is the transition range where both turbos overlap. The Vectra is based on GM's global Epsilon FWD platform, shared with the Chevrolet Malibu/Maxx, Pontiac G6, and Saab 9-3. GM claims that the improved output from "register loading" does not result in higher fuel consumption compared to a single-turbo modern diesel of the same displacement.
I expect expense is the only reason it's not common on petrol engines. It's remarkable how the diesel is being transformed from a tractor to performance engine.....
robnock
21
May 13, 2019 05:29 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
Russ Hill
Aug 31, 2015 06:44 PM
