Bars Leaks... FANTASTIC !!!
Old Mar 1, 2009 | 05:49 PM
Rich_bloor's Avatar
Rich_bloor
rich_bloor@hotmail.com
Default Bars Leaks... FANTASTIC !!!
i tracked my leak down to the raidator....
https://passionford.com/forum/showth...50#post3978850
I was looking at a new raidator, but i thought i'd try some Bars Leaks first.
its worked, been on a run in the car, thrashed it a bit to test it, its still not leaking.
Bars Leaks... RECOMMENDED !!!
Old Mar 1, 2009 | 05:54 PM
Dub604's Avatar
Dub604
I swear by this stuff, used it a couple times and it worked 100%
Old Mar 1, 2009 | 05:56 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Stop being cheapskates - if the car needs a rad, get one.
And people are always moaning about RS's being unreliable and breaking.......if you look after a car properly it'll look afteryou.
Old Mar 1, 2009 | 05:57 PM
TIFF's Avatar
TIFF
Chasing Radders
-WELL said
Bars leak is good for a quick fix......but get the problem fixed not masked
Old Mar 1, 2009 | 06:01 PM
Rich_bloor's Avatar
Rich_bloor
Theres a ressession on !!!
Old Mar 1, 2009 | 06:04 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Some previous owner twat put this shit into the coolant system on my old L200 to try and stop the heater matrix leaking - it didn't work, it clogged the core of the radiator and I ended up having to fork out for a new water pump, thermostat, radiator and heater matrix + assorted coolant hoses
Old Mar 1, 2009 | 06:05 PM
Rick's Avatar
Rick
and it also clogs up the rest of the core and drastically reduces efficiency of the cooling system. You'll need to run some rad flush through the engine before you change the radiator - it's such a ball ache to get rid of.
Old Mar 1, 2009 | 06:06 PM
T3ORA's Avatar
T3ORA
Old Mar 1, 2009 | 09:46 PM
If you bodge it you will only have to do it again.
Old Mar 1, 2009 | 10:36 PM
AlexF's Avatar
AlexF
BODGE!!!
Only use is for emergency repares at the side of the road!
Old Mar 1, 2009 | 10:46 PM
Karl 3dr's Avatar
Karl 3dr
There is absolutely NO WAY i would use that shite on my cossie, i'd rather fork out for a new radiator than risk it going completely tits up and doing more damage!!
Old Mar 1, 2009 | 10:55 PM
markk's Avatar
markk
not long now till you need a new heater matrix either, as it will block that as well !
Old Mar 2, 2009 | 11:53 AM
Bars does indeed block, and it doesn't last.
KALIMEX K SEAL does NOT block and can last indefinitely, I know vehilces over 5 years old treated with this, one wasa a cracked head(waterway) that is still good as new, despite having had subsequent a/freeze done.
K seal contains ceramic fibres though, don't think the others do.
Nov 1, 2015 06:53 PM
155lee
Oct 24, 2015 11:11 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Cos500
Sep 16, 2015 09:50 PM
Tony W
Sep 9, 2015 12:08 PM
