Immobiliser
I'm new to the Passion Ford Forum, I need your help ! Just bought a low mileage ST24 on an r plate. Great car, but its taking me ages to start, I'm finding the immobiliser really fiddly. Is there a modification ? Thanks
Hi Tabetha, Its located in the centre console, seperate from the main key. Insert small dongle first, wait for red light to stop flashing then start car ( or ignition on ). Managed it almost first time this morning. Perhaps I just need to get used to using it, but its driving me mad at the moment !
Thanks for the reply
The small dongle you are using may be worn or more likely the actual small immobilizer port that you insert the dongle isn't making a clean contact. It's probably one of those Cobra things isn't it? Might take you some time getting used to it mate or just rip it out completely and go for a Cat 1 Toad or Clifford.
I was thinking about taking it out, or bypassing it, keen to know if anyone else has done the same. Your'e right about the small contacts being worn, thats why I sitting there fiddling with it sometimes. I looked a right dork on the busy garage forecourt on Friday night !
I've seen one, well my one did not like splashing through 3 feet deep water, at 25mph, water came over bonnet completely and a few drops found thier way throught the rubber grommet halves on the main unit C5T2, but dried out and all was well again, was a lot deeper than I thought!!
Thanks for all the replys. My son has just fitted a Toad ( not sure which model ) to his Pug 306. Will look at that next weekend. Don't feel such a dork now, knowing others have had the same problems.
Thanks
Thanks
