rs overheating
Old Feb 28, 2009 | 10:00 PM
turbozvh's Avatar
turbozvh
Default rs overheating
hello all my erst has just started over heating the water system seems to be over pressurising and popping my hoses. ive checked for blockages and changed the stat it just builds up pressure and starts bubbling in the hoses. is it possible that the head gasket has gone could that be putting the pressure in the water system? although i cant smell fumes from the water tank!!
Old Mar 2, 2009 | 07:33 AM
dazrsturbo's Avatar
dazrsturbo
is the thermostat working?? cud b a problem
Old Mar 2, 2009 | 08:30 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
does it do it if you leave it idling? or does it become aparent when its been on boost?
could be a few things, could start with a leakage test and see if any bubbles show up in the header tank
Old Mar 2, 2009 | 08:06 PM
turbozvh's Avatar
turbozvh
no it does it whe idling aswell just takes abit longer if i left it running eventually it will pop a hose with the pressure ive removed the stat and flushed all the hoses and rad all clear im thinkin now head gasket? could the water pump be drawing in air?
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
