silver zetec piston or black zetec pistons
Old Feb 27, 2009 | 06:50 PM
Matt carter's Avatar
Matt carter
Default silver zetec piston or black zetec pistons
basically can the black top zetec pistons handle boosts? I know that the silver top zetec piston has a stronger crown. So can someone tell me if the black zetec pistons can handle a bit of boost.....http://www.zvh-build.co.uk/contact_m...contact_me.htm
Old Feb 28, 2009 | 10:21 AM
Rick's Avatar
Rick
a tiny bit...
Old Mar 1, 2009 | 07:30 AM
Matt carter
Originally Posted by Rick
a tiny bit...
Im asking this question on behalf of a friend. Cut a long story short, he bought the wrong engine, supposed to get silver top zetec but instead a black top got delivered. He's building a zvh. Basically about 5-6 psi sound about right?http://www.zvh-build.co.uk/contact_m...contact_me.htm
Old Mar 1, 2009 | 07:33 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
If the compression ratio is low enough and it's tuned properly, should be fine.
Old Mar 1, 2009 | 07:42 AM
Matt carter
He's using a decompression plate i might add.http://www.zvh-build.co.uk/contact_m...contact_me.htm
jessie_rs
62
Aug 6, 2019 09:27 PM
Neil Clark
Sep 8, 2015 07:06 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
