Heated Front Screen
Old Feb 27, 2009 | 01:33 PM
JokerDisco's Avatar
JokerDisco
Default Heated Front Screen
HELP.....my heated front screen isn't working. Anybody have ideas what I need to check?
Old Feb 27, 2009 | 04:19 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
does the light come on?there pretty common for not workin
Old Feb 27, 2009 | 06:09 PM
martinmilne's Avatar
martinmilne
my light comes on but it dosent clear !!!
Old Feb 27, 2009 | 07:35 PM
fordsod's Avatar
fordsod
Could you check a relay. It's a gray one near the pink relay.
Old Feb 27, 2009 | 08:46 PM
makaveli96's Avatar
makaveli96
A crack in the windscreen can cause this as it happened to mine and when I got it changed it worked after that.
Old Feb 27, 2009 | 09:17 PM
D4nny8oy's Avatar
D4nny8oy
Fixing the bloody car...
If you've got a multimeter, see if you've got 12volts at either connector to the screen. If you've got power, then remove the clock/courtesy light (2 screws) and check the earth for the screen is tight and clean- it may be minor corrosion between the screw-head and the earth point.
If so, remove the screw and clean-off the rust, then refit. Mine did this several times and cleaning the earth always cured it.
Old Feb 28, 2009 | 07:29 PM
djmillsy's Avatar
djmillsy
Fife Radge
can you get new heated windows still
Old Mar 1, 2009 | 12:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yup, autoglass did mine for £60 through my insurance.
Old Mar 1, 2009 | 03:03 PM
JokerDisco's Avatar
JokerDisco
Light for rear screen works but light does not come on for front screen
checked the grey relay next to the fuel pump relay underneath the steering column - can't see any obvious damage like I could on the burnt out fuel relay I replaced a couple of months back.
Havent got a voltmeter - is there anything else I could try?
Oct 9, 2015 07:38 PM
3drRich
Sep 13, 2015 07:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
YODI
Aug 30, 2015 01:12 PM
C2 MAK
Aug 20, 2015 09:46 PM
