Autronic SM4 Experts! Mark, Chip, Rod, will this work??
Old Feb 26, 2009 | 09:13 AM
olek's Avatar
olek
Default Autronic SM4 Experts! Mark, Chip, Rod, will this work??
hi, take a look at this wiring diagram for an sm4 unit.
gonna be used on a yb-engine.
-std sensor at crank
-autronic hall-sensor at cam/distributor
-autronic ACT-sensor
-standard water temp sensor
-standard TPS
-4 1200cc injectors
-electronic boost valve
-lauch control programmed over output 1, pin7.
-MSD Ignition 8245 Blaster coils.
is this the way to do it?
comments?
Old Feb 26, 2009 | 09:27 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Looks fine to me, but I would hack two lugs off the crank sensor wheel as the Autronic works best on 2 pins typically.
You'll LOVE the boost control if you get it setup correctly with a map of boost value referenced against RPM/TPS, it just drives SO well like that
Old Feb 26, 2009 | 10:10 AM
olek's Avatar
olek
yeah, forgot to say that there's only 2 lugs on the pulley.
just getting the car started now, will go on a Rototest in a month or so.
Old Feb 26, 2009 | 10:29 AM
Chip's Avatar
Chip
Ah, you already knew about the 2 lugs
Im sure Rod might have some info on the multicoil bit of it too, Ive only used it on coilpack so not positive on exactly how the indifvidual coils go without looking at the manual, but you're certainly in the right ballpark with the rest
At least you worked out the 1342 thing on the injectors, loads of people think the 1234 on the ecu refers to cylinder order not firing order!
Old Feb 26, 2009 | 01:08 PM
wes's Avatar
wes
How are you running the coil setup? 4 coils configured for wasted spark?
Old Feb 26, 2009 | 01:23 PM
Chip's Avatar
Chip
He can run either wasted spark or one fire per cylce.
He has them ordered (if you look closely under the coils) as 1342 accordingly, as opposed to simply 1/2 so he is I assume planning on firing them individually.
Old Feb 26, 2009 | 02:11 PM
wes's Avatar
wes
I can see the numbers under the coils, shouldn't they be set to fire in the same order as the injectors? I've followed the lines and they seem to be firing out of sequence, unless i haven't grasped something here?
I have the firing order of the coils in that diagram as 1-4-2-3?
Old Feb 26, 2009 | 02:13 PM
Chip's Avatar
Chip
Yes, you are correct, I'd imagine thats just an error in how he drew the diagram rather than how he was going to wire it though as he got it right on the injectors.
Well spotted, I hadnt noticed that when I had a look at it so your eyes are better than mine (must be true what they say about wanking making you go blind )
Old Feb 26, 2009 | 05:29 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Correct!!
I have told the guy this via a PM . I make these looms on a regular basis & noticed it straight away, didnt really want to contradict Chip so did it via PM.
Old Feb 27, 2009 | 05:47 AM
olek's Avatar
olek
haha, just a small typing error there changed it now.
also sent the coil grounds to pin22, sensor ground, as adviced by Rod.
otherwise it's okay?
is the launch activated when grounded?
Old Feb 27, 2009 | 07:41 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Yes, I usually allocate HSI 2 (pin 24) for that task. With a wheel speed sensor it can be done automatically .
Old Feb 27, 2009 | 08:00 AM
olek's Avatar
olek
okay, cool.
will take it over a switch as it will only be used when something a bit stronger than an old t5 will be mounted
Old Feb 27, 2009 | 02:39 PM
wes's Avatar
wes
Originally Posted by MadRod
Correct!!
Cool, i wasn't trying to catch anyone out, just wondering if i was getting something wrong, i shall be building a loom for my SM4 soon so this subject is somehting i'm quite interesting
Old Feb 27, 2009 | 04:36 PM
RickDraper's Avatar
RickDraper
Can i just confirm that the coils should use the same firing order as the injectors when using individual coils for each cylinder?
Old Feb 27, 2009 | 04:43 PM
Chip's Avatar
Chip
Yes rick they should.
Toe Knee
Aug 23, 2015 08:31 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
