my boot relaease does not work?? any ideas? fiesta rs!
Old Feb 26, 2009 | 08:39 AM
paceo's Avatar
paceo
Question my boot relaease does not work?? any ideas? fiesta rs!
hi guys, my weak side of my car is electrics, basically the boot release does not work in my fiesta rs turbo at all, i have changed the boot switch, purchased a new ignition relay, cleaned the earth for the boot popper and bought the new 4 pin sinsor which screws into the boot!
any other ideas chaps
Old Mar 5, 2009 | 11:40 AM
paceo's Avatar
paceo
up
Old Mar 5, 2009 | 11:41 AM
dojj's Avatar
dojj
Resident Wrestling Legend
are you getting power to the switch?
when you press the button, is there a signal sent to the other end of the wire that triggers the solinoid?
check that first
Old Mar 5, 2009 | 11:51 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You do realise that this will only work without the car running, dont you? (AFAIK)
Old Mar 5, 2009 | 12:50 PM
crazycage's Avatar
crazycage
yes that is right and the ignition off
Old Mar 5, 2009 | 01:32 PM
Oranoco's Avatar
Oranoco
Don't these actually earth through th eboot lid hinges?
Old Mar 5, 2009 | 01:40 PM
Christian and Beccy
#1 in Spelling Club
You've changed the 4-pin switch, but how about the contact side??
Try cleaning that with fine emery or wire wool??
Old Mar 5, 2009 | 02:28 PM
paceo's Avatar
paceo
yes i know they only work with the ignition off, yep cleaned the contact side as well, and checked the fuse in the fuse box
oranoco - they do earth through them hinges.
Old May 14, 2016 | 02:55 PM
RSmark84's Avatar
RSmark84
You ever sort the problem?
Ive just bought a new green relay as one contact had slightly the fusebox. The new relay works only with the rad fan/heater fan/reverse light. But If I refit the other relay only the boot switch will work. The foglights won't work with either relay. Everything did work before I removed the green relay to check why my heater fan screeches
The new relay has a slightly different part number mind(I have yet to try ford direct).
JoeyBoyden
Jan 4, 2024 02:36 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Botts
Aug 13, 2015 04:16 PM
