Would I Need An Engine Crane?
To do an engine swap would i defo need an engine crane? or could i put the engine on stands and lift it from underneath the car? because i dont fancy buying an engine crane because im only going to need it the once...
ideas people?
ideas people?
What engine are you changing?
You would either have to lift the engine up and over the slam panel, or have the engine on the floor and lift the car over the engine! Either way it involves mucho heavy work!
Can you not just borrow 1?
As above, far easier using a crane, i even found you one for 85 quid
http://grizzly.amazonwebstore.com/Gr...oogle-GB&id=uk
Probably a good investment if its an RS Turbo your working on.
yep i do...well im in uni so its gna get deliverd to me in about 2/3weeks when im back in london so il have the weekend to sort it out .. ill be needing it the weekend of the 14th or the 21st
its easy enough to drop them out the bottom, just lower the engine on a jack onto the floor then jack the car up a bit higher so u can slide the engine out, then slide the new one in then lower the car then raise the new engine into place on the jack, ive done it this way countless times on my rs turbos and dose'nt take long
it wouldnt have to be exactly an engine crane, if ou were stuck you could use a chain block and tackle, a forklift, a site loader or like i have used in the past - a tractor and loader and a Cat 312b 360deg tracks machine to take an engine out of my sierra!
really should have taken a pic of that
would make the job a whole load easier if you had an engine crane/hoist
you can hire them from the likes of lord tool hire and the other machinery hire companies, last time i hired one it was 25 quid per day or 60 per week so not a hige cost, and they deliver and collect it
Me and silky16v off here did an engine swap with an XE vauxhall engine by just lifting it out the top of the bay by hand (we chucked a rope round it, put a 2*4 through the rope and put one end each on our shoulders), fuck doing it again though, perfect way to knacker your back!
thanks all for your help and advice...im gna get rsfido_1989 (Darryl) to come down and help me do my engine swap...will take pics and shall have an update from my previous threads of when i blew hole in the engine...cant wait and hope u all read the thread when i post it...its gna be the first time ive done a swap im so excyted
i have one of these bad boys,
mine aint an electric one though like the picture. i have got a cousin who works in the local council and they had a couple going to the bin
