Stu's msd re maps
Old Feb 23, 2009 | 07:12 PM
MAD EVO 4's Avatar
MAD EVO 4
Default Stu's msd re maps
I am able to get one for the new mini cooper 's, if I fit wide band oxygen sensors on the exhaust will the new map take this into account or is the installer able to change the settings in the ecu, as the mini uses narrow band and throws the engine mnagement light on due to running a miltek 200cel cat ?
I hope this makes sence
Old Feb 23, 2009 | 07:24 PM
Graceland's Avatar
Graceland
Team HOTHOT!
You will need a decoder for the wideband to work with the standard ECU as the ECU is expecting a narrowband signal and not a wideband one
Old Feb 23, 2009 | 07:30 PM
MAD EVO 4's Avatar
MAD EVO 4
where can i get a decoder ?
Old Feb 23, 2009 | 08:05 PM
Bobby Singh's Avatar
Bobby Singh
Hi mate I just sent you a pm regarding the mini
Old Feb 23, 2009 | 08:12 PM
foreigneRS's Avatar
foreigneRS
Testing the future
any wideband controller should be able to output a simulated narrow band signal but it won't help. it will still know that you have no cat fitted.
Old Feb 23, 2009 | 09:04 PM
MAD EVO 4's Avatar
MAD EVO 4
It has a sports cat fitted, instead of being a 400cell bmw item, its now a 200cell from miltek
JK12
33
Apr 26, 2021 12:09 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
