ZVH Dipstick
Old Feb 22, 2009 | 12:00 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Default ZVH Dipstick
i have a 2.0 zvh using the 1.8 escort sump do i use the 1.8 dipstick and tube and go off the original marks?
Old Feb 22, 2009 | 03:33 PM
Marts's Avatar
Marts
As far as i have learnt today, the 2.0 dipstick tube is the wrong shape and will foul on the downpipe. 1.8's dipstick tube is sweet for the job
Old Feb 22, 2009 | 04:11 PM
Johnny Knoxville's Avatar
Johnny Knoxville
if you use the 1.8 sump then use the same dip stick
I've seen the difference in the two when in dip stick tube
If you use the 2.0 one you will end up putting more oil in than the 1.8 sump can take
Old Feb 22, 2009 | 04:44 PM
bad boy rs's Avatar
bad boy rs
had this problem on mine cant remember the part numbers, pm alex cab on here and he'll sort them for you thats what i done
Old Feb 22, 2009 | 09:02 PM
Šhatter Box's Avatar
Šhatter Box
you need the all yellow dip stick that comes from an escort or fiesta zetec.
Old Feb 23, 2009 | 12:55 PM
Marts's Avatar
Marts
Got mine coming from Ford. Bit of a confusion tho as they seem to have made one dipstick for the 1.8, but 4/5 different tubes???
I had no idea what my bottom end came from, but think we got it sorted in the end.
Both cost aound Ł15 a piece
Old Feb 23, 2009 | 01:03 PM
Marts's Avatar
Marts
1.8 ZETEC Dipstick - Ł12.50+vat
1.8 ZETEC Dipstick Tube - Ł12.27+vat
to be precise
Old Feb 23, 2009 | 05:12 PM
Johnny Knoxville
I was told to get ones from a 1.6 Zetec with no PAS or Air con
Old Feb 23, 2009 | 05:19 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
as long as the dip stick+tube all came from the same engine as the sump all will be ok. the 2.0 dip stick tube will try to poke through the middle of the manifold where the 1.8 curves around it very neatly
Old Feb 23, 2009 | 05:25 PM
studabear's Avatar
studabear
i've never seen a zetec engined car without power steering
Old Feb 23, 2009 | 05:47 PM
Marts's Avatar
Marts
Ford asked me whether it had power steering or not, so there must have been zetecs without... or the geezer on the phone has a poor knowledge?!
Old Feb 23, 2009 | 05:53 PM
Marts's Avatar
Marts
Im concerned now that I'm gonna be sent the wrong dipstick tube....
What would happen if the wrong tube is used? How 'off' will the reading be on the dipstick?
Old Feb 23, 2009 | 06:35 PM
Johnny Knoxville
I have
DAZZER
Sep 30, 2015 08:43 PM
Brickhouse
Sep 21, 2015 11:00 AM
davidfordrs
Sep 21, 2015 04:23 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
