Bodge? or OK?
21-02-2009, 05:15 PM
Bodge? or OK?
I'm not sure.
Anyway - just cut a piece of pipe to make up the fuel rail (jenvey throttle bodies). I started car it pissed fuel out of both ends.
Is it wrong to put sillicon around the ends, will it hold up to 4.5bar of pressure?
21-02-2009, 05:18 PM
Monte 087
Bodge imo, and i cannot see it making any difference.
21-02-2009, 05:19 PM
Makes enough difference on the dipstick tube and stops that blowing oil out of the seal...
HMMM.
Fúcking set backs!
the petrol will eat through the sillicon i would of thought
21-02-2009, 05:21 PM
14000+ post superhero
petrol will disolve silicone if continually immersed in it.
21-02-2009, 05:22 PM
I guess so.
Fair play - best buy a new one.
21-02-2009, 05:25 PM
Testing the future
very dangerous bodge. do you want your pride and joy going up in flames?
21-02-2009, 05:31 PM
I always say if you bodge it you will only have to repair it again.
21-02-2009, 05:35 PM
how come you cant use the proper alu pipe between the two halves of the rail??
they seal perfectly when cut to the proper length.
(im assuming you are on about the joint in the middle anyway??)
21-02-2009, 05:43 PM
Pics would make things a lot clearer! But silicone is a bodge/
21-02-2009, 05:48 PM
Fucking superstar........
Get some proper loctite thread/pipe sealent.
21-02-2009, 05:51 PM
Silicone is crap anywhere on a car, Hylomar is fuel resistant, once cured but will not hold pressure.
21-02-2009, 06:46 PM
Quote:
Originally Posted by
pee vee
Fucked it up!
Getting new pipe tomorrow, so pissed off with it I just wanted to get it done.
Did some other stuff to the car instead.
21-02-2009, 06:56 PM
I'm guessing this is the bit that slids in two o rings? If so then it must be the right external diameter.
21-02-2009, 07:16 PM
I have some of that pipe if you get really stuck.
21-02-2009, 08:38 PM
Picking some up tomorrow - Thanks for offer
Doug - it was 1mm out.
Bastard thing!
Bodge22
11
03-06-2006 06:08 PM
Bodge22
13-04-2006 10:47 AM
Bodge22
22
07-04-2006 10:22 AM
Bodge22
Ford Mondeo Including ST
07-02-2006 09:13 PM
Jim Galbally
13
26-07-2004 02:01 PM
