s1 and s2 dipsticks the same ?
Old Feb 21, 2009 | 04:33 PM
B1G_RST's Avatar
B1G_RST
Default s1 and s2 dipsticks the same ?
got a s1 block in my s2, lost the dipstick, got a s2 dipstick from a mate, but it doesnt feel right
aye the sticks the same? and are the tubes the same lenght ?
cheers
Old Feb 21, 2009 | 04:35 PM
DazC's Avatar
DazC
I don't think they are the same length to be honest. The dipsticks are deffinately different.
Old Feb 21, 2009 | 04:51 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Length is probably the same but the S1 has a oil level sensor on it for the oil level light on the dash (oil level, not pressure).
Old Feb 21, 2009 | 05:21 PM
adam151082's Avatar
adam151082
Theres 2 dipsticks for the s2, a pre 90spec has a metal end and the 90spec one has a plastic end (just been readin a buyers guide for a s2).
dont know if this helps i just wanted to be a smart arse
Old Feb 21, 2009 | 06:06 PM
gaz s1's Avatar
gaz s1
the s1 dipstick tube is shorter than the s2 as i had to cut down a s2 tube as the s1 is no longer avaliable from ford.
The dipsticks are a different length, important that you have the right dipstick for the tube you have in your block
Old Feb 21, 2009 | 10:24 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
i've change metal for a plastic, no problems with heat now...
Old Feb 22, 2009 | 01:38 AM
ram's Avatar
ram
Has a large member
the s1 dipstick/tube are different in length to the s2 ones cant remember which but i wouldnt use your car until you got the right one as you wouldnt wanna over/under fill!
edit to say just saw gaz's post above. that'll be the right answer then lol
Old Feb 22, 2009 | 09:41 AM
B1G_RST's Avatar
B1G_RST
cars not getting used just now,, hasnt been for months
anyone no then if i change the s1 tube to a s2 tube then it will giive me the correct reading ??
Old Feb 22, 2009 | 08:42 PM
gaz s1's Avatar
gaz s1
i take it if you are using the s2 dipstick, then you need the longer s2 tube, still avaliable from ford
Old Feb 22, 2009 | 09:04 PM
B16CVH's Avatar
B16CVH
I brought an S1 years ago, the guy fitted an S2 tube with an S1 stick and filled it to the max, oh boy, yes there was about 8 litres in the bastard, only realised when i booseted it and covered every square inch of the polish bay
Old Feb 22, 2009 | 10:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Oooooops
Old Feb 24, 2009 | 10:23 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
can get the tube off this one mate if you need it!
DAZZER
Sep 30, 2015 08:43 PM
Brickhouse
Sep 21, 2015 11:00 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
muffster
Aug 17, 2015 08:17 PM
