S2 missfire on boost
Old Nov 27, 2004 | 04:33 PM
Paul's Avatar
Paul
Default S2 missfire on boost
Only recently my S2 has started to missfire onboost at 10psi and above, i've look at the plugs and tehy are fine leadas are newish so is the dizzy, rotor arm and cap. What else could it be?
Old Nov 27, 2004 | 04:57 PM
KSA-Cossie's Avatar
KSA-Cossie
Connection to and or the amal valve.
Old Nov 27, 2004 | 05:02 PM
Paul's Avatar
Paul
connection is fine to that
Old Nov 27, 2004 | 05:06 PM
KSA-Cossie's Avatar
KSA-Cossie
And what about the valve itself?
Old Nov 27, 2004 | 05:11 PM
Paul's Avatar
Paul
dunno lol how can i tell if its playing up ?
Old Nov 27, 2004 | 07:40 PM
Wazzzer's Avatar
Wazzzer
it should click a couple of times when you turn the ignition to the second stage...
Old Nov 27, 2004 | 07:45 PM
apples24's Avatar
apples24
if you need one i have a fully working s2 amal valve
in experiance with boost probs on rsts its been plug and lead related, id also look for leaking hoses, colapsing hoses, timing , co levels etc all basic stuff but never say its a newish set of plugs/leads cant be that
some just give up the ghost so early its unreal
im no expert but every little helps aye
Old Nov 28, 2004 | 09:24 AM
James Raby's Avatar
James Raby
I had misfire on boost recently, cured with new cap and rotor arm...
Got to sort my cold start problems out now ROFL
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
