cossie - no spark or fuel pump buzzin HELP?
Old Nov 27, 2004 | 03:07 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Default cossie - no spark or fuel pump buzzin HELP?
Hi, mates 3 door cossie decided to cut out today, no spark or fuel pump....what could be the prob?
Old Nov 27, 2004 | 03:13 PM
dave cos4x4's Avatar
dave cos4x4
Not sure if it will be the crank position sensor, think that has something to do with the others not working.
Not 100% though, sorry.
Dave.
Old Nov 27, 2004 | 03:19 PM
vroooom ptssssh
It Wasnt Me!
thanks Dave, i'll pass it on, i thought maybe a dodgy ECU earth, or dodgy ECU?
Old Nov 27, 2004 | 03:24 PM
pau1rs's Avatar
pau1rs
check the fuses for the relays on the loom too.. one blew on me s2 on L6 and killed the fuel pump
Old Nov 27, 2004 | 03:25 PM
dave cos4x4
Quite possibly the earth,this happened on my saff iirc.
Got the AA out and found it, could give them a ring to say it has broken down.
Give the ecu a good mess with too., i.e. unplug it a few times .
hope you sort it.
Dave.
Old Nov 27, 2004 | 03:41 PM
vroooom ptssssh
It Wasnt Me!
thanks guys
Old Nov 27, 2004 | 03:49 PM
pugo's Avatar
pugo
turn ignition on, connect a small wire from the +12v side of the battery to the +12v side of the coil, and then crank it over
If it runs you have a relay or fuse gone down on the ignition switch side of the ecu or your alarm is playing silly buggers
Pugo
Old Nov 27, 2004 | 04:21 PM
lancia delta 6 times WRC's Avatar
Could be the pick up in the dizzy
Old Nov 27, 2004 | 04:32 PM
jayRS's Avatar
jayRS
only think i can think of that may make theses related is the relay or ecu, not much help, sorry
let us know what it was when its sorted, and what it was.
Old Nov 27, 2004 | 06:15 PM
vroooom ptssssh
It Wasnt Me!
told him to check all the things said above he'll check em tommorow an i'll let you's know thankyaaaz
Old Nov 28, 2004 | 08:31 PM
jayRS's Avatar
jayRS
has he checked the fuel cut off switch?
Old Nov 28, 2004 | 08:35 PM
vroooom ptssssh
It Wasnt Me!
dunno think he was havin a look at it today but aint heard from him i'll txt him tommoz an tell him to give it a look, but no spark either so i got a feeling its the earth for the ECU....soon find oot tho, will let you know when i do
Old Nov 28, 2004 | 08:39 PM
jayRS's Avatar
jayRS
ok mate, not sure where it would be? i think on the cossie it might be in the boot under the spare wheel, if not in one of the foot wells behind the trim, drivers side i think
could be a burnt out rotor arm for the spark, or wanked coil/lead or wires to it?
Old Nov 28, 2004 | 08:47 PM
marco polo's Avatar
marco polo
hi mate
it's the igniton amp has pack up....it bolted on the inner wing beside the battery
this sends power to the pump
Old Nov 28, 2004 | 09:05 PM
vroooom ptssssh
It Wasnt Me!
Nice one Marco, thanks & thanks Jay i'll let him know
Old Nov 28, 2004 | 09:08 PM
jayRS's Avatar
jayRS
no probs dude, im guessing really mate without being at the car its hard to say, marco is prob right though as i didnt give it a thought.
all helps though.
Old Nov 28, 2004 | 09:14 PM
vroooom ptssssh
It Wasnt Me!
yea it's hard to tell eh, he's near carlisle and i go ta fone call to see if i knew what it could be, mentioend a few things but thot best to post here, cheeRS
Old Nov 28, 2004 | 09:16 PM
jayRS's Avatar
jayRS
im on the isle of wight so i couldnt exatly go have a look eathier lol
Old Nov 28, 2004 | 09:18 PM
vroooom ptssssh
It Wasnt Me!
lol
Old Nov 28, 2004 | 09:20 PM
jayRS's Avatar
jayRS
would help if i could spell too lol not my fault im "dis-leps-quick" lol
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
