Zetec Conversion into MK4...What do I need to change?
Old Feb 8, 2009 | 06:15 PM
ford_lover77's Avatar
ford_lover77
Mk4 Escort Estate
Default Zetec Conversion into MK4...What do I need to change?
I'm in the process of putting a zetec into my MK4 escort estate but need to know what I need to change!! Any help please?
Old Feb 8, 2009 | 07:09 PM
rst in breaking's Avatar
rst in breaking
engine mount needs modifying, if its a 2.0l your poss need oil pump, i bvelieve the water pump works the wrong way but not sure so may need to swap to a 18 esc one along with sump and pic up then obv engine loom needs wiring in too. good luck
Old Feb 8, 2009 | 07:12 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
look up my post in the piccy section mate,tells ya pretty much everything u need to do with pics!
Old Feb 8, 2009 | 07:14 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
your right the water pump goes the wrong way you need one foo a 1.8 zetec like an escort gti one. you will also need a cvh alt bracket and to fit a zetec alt pully with a small spacer
Old Feb 9, 2009 | 06:12 PM
ford_lover77
Mk4 Escort Estate
Default Engine mounts?
Where can i get some engine mounts? its a 1.8 gti lump
Old Feb 9, 2009 | 06:14 PM
orion_crazy_carl
orion=mini saff
just cut the lug off your CVH one
Old Feb 9, 2009 | 06:30 PM
ford_lover77
Mk4 Escort Estate
they're buggered. need new ones but which will fit?
Old Feb 9, 2009 | 06:33 PM
orion_crazy_carl
orion=mini saff
there?theres only one on the left side?or u mean the gearbox ones?
Old Feb 9, 2009 | 06:42 PM
scoobypete's Avatar
scoobypete
any chance you could post up link as i carnt find it anywhere
JK12
33
Apr 26, 2021 12:09 PM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
marky_g
Sep 12, 2015 04:26 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
