S2 rst problems again.. SOLVED! :)
Old Feb 21, 2004 | 11:50 AM
Default S2 rst problems again.. SOLVED! :)
Hello again!
i had some problems in january
https://passionford.com/forum/viewto...702&highlight=
And i changed the fuel distributor, but the ecu still needs
that vent so it works.
I have changed following parts:
Fuel distributor
Ignition distributor
Ecu / and jetronic box
Throttle position sensor
Air tempeature sensor
Fuel filter
spark plugs
ecu is chipped now.. when i remove the vent from ecu's pipe the ignition advance goes erratic on boost. It has no power at all.
Timing advance is 9°, i also tried 11° but it knocks 4 and fifth gear.
Setting #1
When i tight the ecu pipe vent ( less pressure going ecu) car runs better and has more power but knocks easier.
Setting #2
I open the vent ( more pressure going to ecu) not knock at all, but no low rpm power.
Yesterday i tested 8° ignition, and open the vent more..
1.0 bar and not knock but low rpm and vacuum car is like corolla, no power at all.
What should i try next?
-Antti Orava
Finland
Ps. sorry my bad english again
Old Feb 21, 2004 | 02:17 PM
PJay's Avatar
PJay
Putting a restriction in the pipe to ecu will cause all sorts of problems and is NOT required on any state of tune RST
Old Feb 21, 2004 | 02:50 PM
Yep, but if i take the vent off the car wont work at all and it popping etc.
Old Feb 22, 2004 | 01:21 PM
Anyone got idea what i should do next?
Next week i will buy new spark plugs and wires, and maybe try other distributor also..
Old Feb 22, 2004 | 01:38 PM
PJay's Avatar
PJay
That vent goes to a MAP sensor in the ECU that is probably why you have problems, it MUST be attached
Old Feb 22, 2004 | 03:24 PM
Hmm.. i think you now get wrong what i mean.
That pipe from intake manifold that goes in ecu is attached of course.
I mean that car wont work without that screw (pressure limiter) in pipe.
Old Feb 23, 2004 | 05:44 PM
Problem solved.
We adjusted the advance without taking the pressure pipe off from ecu earlier and now take the pipe off and turn ignition there where it should be 12° and now car works without any screw in ecu pipe.
Thanks for help!
A.t.p
Oct 23, 2015 07:54 PM
DAZZER
Sep 30, 2015 08:43 PM
A.t.p
Sep 29, 2015 05:04 PM
