Need new suspension: springs/dampers or coilovers?
Old Feb 3, 2009 | 11:21 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Default Need new suspension: springs/dampers or coilovers?
I'm looking at replacing the aging standard suspension on my saff. Years of abuse has left the dampers a bit soggy, and some tool's probably cut the springs
What do you recommend as a decent replacement - bear in mind I have three fillings so springs made from granite aren't an option. Need somthing that's good for every day use, but still gives better-than-standard handling.
And, how (if at all) are coilovers better than standard springs/dampers? Is there any benefit to having them?
Old Feb 3, 2009 | 11:40 AM
Twellsie's Avatar
Twellsie
Koni's with Ahmed springs
Old Feb 3, 2009 | 05:25 PM
Depends what sort of ride you like, you know what coilovers are like from my car, a nice direct feel but a bit hard, that's what I like though.
If I was going for something with comfort I would go KONI adjustable, with chassis dynamic std ride height springs, these still drop around 1", despite thier name.
If you are off this week you can have a drive of mine to see how you like it.
If you don't want a hard ride, the only advantage of coilys is setting the height, or corner weighting.
Old Feb 4, 2009 | 10:58 AM
Remko GT's Avatar
Remko GT
I've found my Sierra handles like a dream on the road on Koni adj and Apex lowering springs. Not too harsh but stiff, direct and still comfy.
Old Feb 4, 2009 | 11:16 AM
cozmeister's Avatar
cozmeister
More boost Igor!
My mate at work who used to do rally cross and grass track racing many years ago has said not to ignore Spax - any opinions?
Old Feb 4, 2009 | 11:32 AM
Paul_RS's Avatar
Paul_RS
Konis and Ahmed springs from Rainbummer.
Old Feb 4, 2009 | 11:52 AM
My dads running(cossie) spax on his 4i, they are very good, have come a long way since they were taken over by the frenchman, even used on THRUST SSC!!
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
