haynes manual
Old Feb 1, 2009 | 09:19 PM
RSGUESTY's Avatar
RSGUESTY
Default haynes manual
need a haynes manual for my cossie but arent sure which one to buy as ther are a few different ones ebay. is it the 903?
Old Feb 1, 2009 | 09:45 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
the haynes manuals i see at halfords say on the back cosworth not included
Old Feb 2, 2009 | 07:14 AM
Look on ebay cause you can buy the ford workshop manual on a dvd i think i paid about a tenner for mine.
Old Feb 2, 2009 | 07:53 AM
As said Haynes don't do a cossie manual, but the other ones like 903 cover the mechanical bits that are the same on a cossie as std sierra, It's mainly the box, rack, diff, ecu that are different apart from the engine of course, lots of other little bits too.
The std manual 903 does not cover(I think) V6's, but the 904 does, either one will do, I have both and the 903 has got to be the better one.
Old Feb 2, 2009 | 04:35 PM
Jimboxr4x4's Avatar
Jimboxr4x4
You can download all the cosworth manuals here :
http://www.siipicossu.com/manuaaleja/manuaalit.htm
Old Feb 3, 2009 | 06:14 AM
RSRoy's Avatar
RSRoy
BIG thanks for that link, will download some of them
Old Feb 3, 2009 | 05:18 PM
martysmartie's Avatar
martysmartie
The electrical equipment is the same as that of a 'Ghia' model so I always use the normal Sierra manual for wiring diagrams and reference and the 2WD shell is same as any other Sapphire shell.
4x4 has reinforced wings in addition and supposidly 2WD has foam in the A pillars but never checked that.
So really only things different are mentioned earlier.
Tabetha out of interest whats the difference between normal sierra rack and Cosworth one?
Kind regards,
Martin.
Old Feb 3, 2009 | 10:53 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Kind regards,
Martin.
I believe it's the same ratio as a standard one but only 2.6 turns lock to lock as oposed to 3 as the rack is restricted.
Old Feb 4, 2009 | 11:59 AM
The rack has got a limited throw compared with normal racks, so as not to rub on full lock.
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
THE RADMAN
Sep 19, 2015 12:57 PM
markk
Sep 9, 2015 08:11 AM
fuzzy
Sep 4, 2015 10:11 PM
