escort cosworth fuel pump wiring
Old Jan 29, 2009 | 11:51 AM
fudaga's Avatar
fudaga
Default escort cosworth fuel pump wiring
Here's a diagram that me and my m8 put together. Is this any good? Any recomendations?
Is the 32a fuse enough? I'm running a wallbro uprated intank pump. The original wiring stays in the car but this is only for the fuel pump.
Old Jan 29, 2009 | 12:45 PM
olek's Avatar
olek
that wont work at all, m8.
the pins on the relay must be:
30 - connected to the battery+
87- connected to the fuelpump+
86- signal
85- earth
why do you both need a inertia switch AND a "start switch"?
use the orginal wire to the fuel-pump as the signal-feed.
a 30 amp fuse should do it.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
