Will it ever work again
Old Jan 27, 2009 | 08:36 PM
Its Dave's Avatar
Its Dave
Default Will it ever work again
Had a few hours spare tonight so l did this
Now l can cut that bloody small turbo ecu loom out in the comfort of my sofa
Just hope it work work again when its back together
Old Jan 27, 2009 | 08:38 PM
LHD220Turbo's Avatar
LHD220Turbo
i hope you aint coloured blind!
Rax's Avatar
Rax
I hope them two didnt help
Old Jan 27, 2009 | 08:39 PM
kev 3dr's Avatar
kev 3dr
Doh At least the Kittens know what they are lookin at Dave !!!!
Its Dave's Avatar
Its Dave
They like the taste of the plugs
Old Jan 27, 2009 | 08:43 PM
ECU Monitor Enthusiast
Dave, I dont see any problems there You arent in the photo lol
Just take your time putting it back in and double check everything before reconnecting the battery.
Old Jan 27, 2009 | 08:46 PM
Twellsie's Avatar
Twellsie
that would be my worst nightmare, me and electrics dont go, lol
Old Jan 27, 2009 | 08:47 PM
Rax's Avatar
Rax
Lol,looks like fun.If you are altering,one tip if you dont know.When joining,solder do not crimp.When i used to make looms for anything automotive we were never allowed to use connectors.
Old Jan 27, 2009 | 08:49 PM
kev 3dr's Avatar
kev 3dr
Strange as i thought soldering allways weakend the wiring or is that just for doing stereo work ???
Old Jan 27, 2009 | 08:50 PM
Its Dave's Avatar
Its Dave
I have already cut out the clifford and re soldered the wires
Just need to get rid of all the bullet connectors, had a count and there is a good 20+
J1mbo's Avatar
J1mbo
B1mbo
good luck dam i hate wiring !
simon170's Avatar
simon170
Old Jan 27, 2009 | 08:53 PM
Rax's Avatar
Rax
I think with stereo work it all depends on what you are actually doing ie current/heat.Soldering is more reliable for looms.
Old Jan 27, 2009 | 09:01 PM
SOldering is like any other job, its only good if done properly.
Soldering is always the best option in all circumstances for longevity.
However, it takes loads of practice to get right and you must use the right grade of solder at the right temperature on clean wire ends that has been cut and trimmed properly.
Old Jan 27, 2009 | 09:03 PM
Its Dave's Avatar
Its Dave
My painter will be happy to find out he dont have to mask any wires now
Old Jan 27, 2009 | 09:11 PM
Rax's Avatar
Rax
Its all about resistance too with joints.Not meaning to do this It was my job for 14yrs making looms for aerospace military and commercial stuff and training agency or existing employees on new jobs.From small stuff using a microscope to big things.You should try soldering the connectors to make tank battery leads lol.
Old Jan 27, 2009 | 09:26 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
I want to do that with my full car and cosworth loom as i dont have any wiring diagrams for the link so its test and find out as i go along at moment.
It all works so im leaving it alone till i strip out interior when access will be easier.
Old Jan 27, 2009 | 09:32 PM
Its Dave's Avatar
Its Dave
I took it out really to make the painters job easer, also wanted to cut out the small turbo loom.
When l saw sean old cossie he had the loom that goes in front of the blower relocated inside so you can remove that plastic bulkhead panel, so thats what im going to do with YUM
Old Jan 27, 2009 | 10:11 PM
westus1's Avatar
westus1
i love it when i got a wiring loom in a big heap like that
gets the brain switched on figuring it out
you get a nice sence of achievement when it all goes back together and works
defo solder all the joints
Old Jan 27, 2009 | 10:26 PM
Psycho Warren
Carbon Crazy
fair enough dave!! Mines got 2 fuse boxes and a complete set of relays to run engine loom of cossie lump and all the old relays to run the old puma lump where as id have wired it in so cossie loom uses original relays to simplify things. plus i want to strip out all the excessive stero wiring etc
Old Jan 27, 2009 | 10:28 PM
westus1's Avatar
westus1
just run it with a 4x4 cossy engine loom,
2wd's work too but the 4x4 is tidier
couple relays, an ecu and about 5 wires
no need for fuse box's or masses of wires to get a yb running
very simple to wire up
Old Jan 27, 2009 | 10:32 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Depends on the application - F1 is all crimped - no soldering allowed. WRC, solder where you want - but you have to tiewrap it down to a block after to prevent vibration.
Dave - just put it back together somehow
Old Jan 27, 2009 | 10:42 PM
westus1's Avatar
westus1
just wrap the wires together and tape them, it'll be fine
Old Jan 27, 2009 | 10:45 PM
mk1escoz4x4's Avatar
mk1escoz4x4
good luck
Old Jan 27, 2009 | 10:48 PM
Big Will_'s Avatar
Big Will_
Don't give him ideas
Old Jan 27, 2009 | 10:50 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Good commitment dave
and PMSL at that tech support picture!
Old Jan 27, 2009 | 10:52 PM
burnzy's Avatar
burnzy
burnzy
lol i've seen that enough, why oh why do people do it, the best so far was my mates e36 beemer some proper chav had fitted crap dials and led's all around the car it was such a mess wish i had pic's now, it was shameful to say the least
Old Jan 27, 2009 | 10:57 PM
Miller 3's Avatar
Miller 3
Be nice to see the pics when its done
Old Jan 27, 2009 | 11:09 PM
FletchCossie's Avatar
FletchCossie
Twist n tape, twist n tape, twist n tape...
Dave's next post would be "Well look what I melted today (No, the engine's fine this time)
Ive gotta do this to my 4x4 loom at some point. When shall I drop it off Dave
Old Jan 27, 2009 | 11:21 PM
Psycho Warren
Carbon Crazy
It has Large turbo cossie 4wd engine loom. pumas have engine and interior fuseboxes.
At moment I been trying to get heated front screen to work yet when i pull the windscreen fuse out, the engine stalls so someones been using the circuit to run the engine loom
Old Jan 28, 2009 | 06:28 AM
Its Dave's Avatar
Its Dave
Wont be doing this again
Old Jan 28, 2009 | 10:29 AM
FletchCossie
You say that now, wait till your half way through and saying "How much can I pay someone to do this?"
Old Jan 28, 2009 | 10:30 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
fuck that Dave. thats why Mark and Rod took care of all my loom stuff
Old Jan 28, 2009 | 10:43 AM
Its Dave's Avatar
Its Dave
Rod will be making my ECU loom
As for the main loom that needed to come out for painting and relocation also get rid of a lot of bullet connectors
Old Jan 28, 2009 | 11:23 AM
COCHYN's Avatar
COCHYN
Get those feckin' cats away from the wires, marking territory and wires don't mix
Old Jan 28, 2009 | 11:29 AM
Rs1's Avatar
Rs1
Ive done something similar recently, i pulled the full car loom out of my nova to make a new one then make a new ecu/engine loom up seperate to that all with new fuses/relay boxes, power distribution boxes etc.... do away with wires that aren't needed just like yourself.
Half way through and the headaches have started,lol. I knew i shouldn't have butched the old loom to get it out quick.
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
