FAO Stu
Old Jan 27, 2009 | 04:09 PM
Paul_RS's Avatar
Paul_RS
Default FAO Stu
My air injector arrived today
I'm just wondering if i have it built up the right way round??
Incase its not clear, the tiny bleed hole is on the right. Have i assembled it correctly?
Old Jan 27, 2009 | 04:31 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
boost pressure in the top of the injector
regulated control pressure bottom of the injector to waste gate, bleed jet in this end
Old Jan 27, 2009 | 04:58 PM
Tim's Avatar
Tim
does a single inj have enough flow to control the boost correctly ? just askin as when i got mine there were 2?
tim
Old Jan 27, 2009 | 05:09 PM
Twellsie's Avatar
Twellsie
i believe most of the newer type air injectors only have 1
Old Jan 27, 2009 | 08:03 PM
Paul_RS's Avatar
Paul_RS
Thank you Sir Best swap that about before i forget
tim
Yeah, the single ones flow 1200cfm (if i remember what Stu told me correctly) and the doubles flow 600 per injector, so both units flow the same.
Old Jan 27, 2009 | 09:33 PM
Stu @ M Developments's Avatar
PassionFords Creator
Paul is correct about flow. :dd:
Please follow Tony's advice and swop the bleed to wastegate end, other than that, perfect pal. Apologies too, i normally build them but was up against it yesterday and just thought, does he want it DIY next day, or Built the day after, i chose the former, hope you don't mind?
Old Jan 27, 2009 | 10:11 PM
Paul_RS's Avatar
Paul_RS
Not a problem at all dude! Took 2 seconds to put together, i'm smart enough to know not to guess at this though. Knowing my luck i'd guess wrong and blow something up
Just need a dry day to fit/test it - Don't suppose you can arrange on over here for me?
GTR_STU
Aug 28, 2015 01:02 PM
Bailes1992
Aug 16, 2015 07:14 PM
