Recording a Windows app..
Old Jan 27, 2009 | 09:49 AM
SapphyMike's Avatar
SapphyMike
Default Recording a Windows app..
Is there any way of logging a Windows application for when its been opened and closed?
Old Jan 27, 2009 | 10:11 AM
Markb_s1's Avatar
Markb_s1
Is this fro work or home?
we've got a few things here that can do it but none of them are free... we usually use altiris notification server application metering for start/stop events or something called scalable survey which also provides usage data.
Old Jan 27, 2009 | 11:08 AM
SapphyMike's Avatar
SapphyMike
Its for work - for a customer - need to try and find out if one of our apps is being closed by someone.
Old Jan 27, 2009 | 11:46 AM
Markb_s1's Avatar
Markb_s1
presumably this would need to be very cheap or free then? in which case ignore both my suggestions above!
Old Jan 27, 2009 | 12:09 PM
SapphyMike's Avatar
SapphyMike
Yes LOL.
Cheers anyway!
Old Jan 27, 2009 | 12:14 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
If its one of your apps, can you not just get it to write data out when it is closed?
Or are you meaning if someone does ctrl-alt-delete and kills the process or whatever?
Old Jan 27, 2009 | 12:33 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Enable Process tracking auditing Start -> Settings -> Control Panel -> Administrative tools -> Local Security Settings
Goto Local Policies -> Audit Policy, and enable Success and Failure auditing and click OK. You should then see events such as program starting and exiting in the Windows Security Event Log with the category Detailed Tracking.
http://technet.microsoft.com/en-us/l.../cc775520.aspx
Old Jan 29, 2009 | 03:12 PM
cozmeister's Avatar
cozmeister
More boost Igor!
How did you get on?
chowfornow
14
Jan 5, 2019 09:01 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
