MK3 MK4 escort cabriolet owners with electric windows? please help!
Old Jan 26, 2009 | 11:41 PM
ezzer's Avatar
ezzer
Default MK3 MK4 escort cabriolet owners with electric windows? please help!
Im fitting MK4 escort cabriolet electric windows to my Mk3. Im only testing at the moment as I didnt want to fit them then not work.
Ive got the loom & motor etc all linked up and working, but the passengers side window is alot slower when operated from the passengers side!! when operated from the drivers switch it runs as fast as the drivers side. Any one else had similar problems? Ive tried takin the feed from the drivers side to power the passengers but its still slower. PLease help as im very confused? thanks
mike
Old Jan 26, 2009 | 11:44 PM
studabear's Avatar
studabear
try unplugging the switch on the passenger side and bridge the wiring with a split pin to see if window goes at full speed, if it does the switch is dodgy
Old Jan 27, 2009 | 09:10 AM
BillyCabrio's Avatar
BillyCabrio
What loom are you using as their different between the 2 Mk's...
Old Jan 27, 2009 | 09:22 AM
ezzer's Avatar
ezzer
i will try & bridge the wiring on the passengers side & see what happens, Im using MK4 looms. cheers
Old Mar 2, 2009 | 01:23 PM
Dr Knockers's Avatar
Dr Knockers
i'm trying to fit e/windows and c/locking into a mk3 too, but the relay module does not seem to work, r u using a mk4 relay module? Sorry for hijacking this thread, just stuck for how to move forward with mine.
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
