Any mathmeticians here?
Could any work out these equations using the substitution method please:
1.
x= 6y-2 equation 1
8y- 3x = 1 equation 2
2.
t = 1 - 7s equation 1
5s - 3t = 10 equation 2
3.
3p + 7q = 11 equation 1
p - q = -4 equation 2
4.
2d + e = -8 eqaution 1
6d - 2e = -27 equation 2
thanks
1.
x= 6y-2 equation 1
2.
3.
4.
thanks
Dude, do you or your child seriously have a problem in substituting into equations? Getting someone to do it isn't going to solve your problem. Go to your teacher/lecturer and get them to help you
Thanks anyway.
Is many years since i did it last but I come to a different solution to the one posted above.
Q1. X=1 and Y=0.5
Workings: Substitute x in terms of y so the first part now reads:
8y - 3(6Y-2) = 1
Multiply out the brackets to give:
8y - 18y + 6 = 1
Subtract 6 from both sides:
8y - 18y = - 5
-10y = - 5
Divide both sides by 10:
- y = - 5/10
Multiply both sides by -1:
y = 5/10 = 0.5
Feeding y=0.5 into original equation for x:
x = 6 x 0.5 - 2
x = 3 - 2
x = 1
Hopefully you can do the other 3 questions yourself!
Q1. X=1 and Y=0.5
8y - 3(6Y-2) = 1
8y - 18y + 6 = 1
8y - 18y = - 5
-10y = - 5
- y = - 5/10
y = 5/10 = 0.5
x = 6 x 0.5 - 2
x = 3 - 2
x = 1
Tell the school then bud because it won't help matters especially when they get onto harder stuff and will need to make substitutions for other problems. I am currently at uni doing a mechanical engineering degree and I have core maths modules so I'd like to think I know my stuff. From experience, you have to nail these things on the head right from the beginning to I would go to the teacher and tell him/her your child has a problem and to help her sort it out. If the teacher is at fault for not being able to explain properly try addressing the head of department.
Q1. X=1 and Y=0.5
8y - 3(6Y-2) = 1
8y - 18y + 6 = 1
8y - 18y = - 5
-10y = - 5
- y = - 5/10
y = 5/10 = 0.5
x = 6 x 0.5 - 2
x = 3 - 2
x = 1
Q1. X=1 and Y=0.5
8y - 3(6Y-2) = 1
8y - 18y + 6 = 1
8y - 18y = - 5
-10y = - 5
- y = - 5/10
y = 5/10 = 0.5
x = 6 x 0.5 - 2
x = 3 - 2
x = 1
My daughter says thanks for the help and gives you a hi5,
She also asked me to tell everyone else thanks for refreshing her memory.
ricky
