ERST CV BOOT replacment help!
Old Jan 26, 2009 | 03:46 PM
t31ryt's Avatar
t31ryt
Default ERST CV BOOT replacment help!
Hi passenger side outer needs replacing does anyone recomend the split ones or are they as crap as they look?
Old Jan 26, 2009 | 04:08 PM
rs combi's Avatar
rs combi
dont use them mate they usualy split again only 20 min job to do anyway so you might as well do it with a proper one then you dont have to worry abbout it
Old Jan 26, 2009 | 04:17 PM
t31ryt's Avatar
t31ryt
bummer i havnt got section 8 of the manual can u give me some quick tips?
Old Jan 26, 2009 | 04:27 PM
Micky's Avatar
Micky
1.remove big nut of end of cv joint
2.diconnect anti roll bar,steering arm and track control arm off the hub carrier
3 pull the hub carier towards you to slide the cv joint out the back of it.
4 remove old boot and refit new boot.
5 reassembly all back together, its reverse of removal!! Love that haynes saying!!
Micky
tankybaby66
Feb 6, 2016 02:24 PM
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
