Focus Fusebox help
Old Jan 25, 2009 | 08:52 PM
djsri's Avatar
djsri
Default Focus Fusebox help
Hi
Has anyone got any info on this fusebox. I'm looking for the dip beam and full beam fuses. Its in a Focus titanium 56 plate but the owners manual is a different layout
Thanks
Old Jan 25, 2009 | 10:17 PM
James's Avatar
James
are you sure the manual is on the right page?
the manuals are usually spot on!
Old Jan 26, 2009 | 10:28 AM
djsri's Avatar
djsri
No, def right page
This is what the manual pic looks like!
So i have no idea now..
Old Jan 28, 2009 | 11:39 AM
Kirki's Avatar
Kirki
I have exactly the same problem (on a 07 model, actual layout doesnt match the handbook) so if anyone could help I would be really grateful.
Old Jan 28, 2009 | 02:24 PM
220tel's Avatar
220tel
i have checked in the manual i have for a 57 plate st and it is the same as above
good old ford
Old Jan 28, 2009 | 08:22 PM
B19 JUB's Avatar
B19 JUB
ford have been a bit slow on updating their manuals.your fuse box is late type.
just been on etis(ford tech site) and fuses for dip beam are 142 and 143 in pass fuse box.there are more further back up the system,135 in fuse box,114 and 115 for headlamp switch and cluster supply
main beam fuses are 139 and 140 in pass fuse box.
hope it helps.
Old Jan 28, 2009 | 10:26 PM
djsri's Avatar
djsri
Thanks for the info guys
B19 JUB
Thank you for checking thats great, but my fuse box seems to be labelled as F00 and so on not just numbers?
220tel
Are you able to scan a copy for me please?
Old Jan 28, 2009 | 10:43 PM
B19 JUB's Avatar
B19 JUB
sorry my fault.there should be an f in front of those numbers depicting its a fuse.ie r means its a relay.ill double check on a focus of your year at work tomorrow ok
Old Jan 28, 2009 | 11:01 PM
djsri's Avatar
djsri
Thumbs up
Top man thanks m8
Old Jun 1, 2009 | 05:04 AM
hancock444's Avatar
hancock444
Hi = I have the same problem, handbook gices the images as the previous poster uploaded, whilst my fusebox is as the photo! Which fuse is the cigerette lighter?
Old Jun 6, 2009 | 05:12 AM
hancock444's Avatar
hancock444
any one?
Old Jun 13, 2009 | 05:53 PM
Buckster_uk's Avatar
Buckster_uk
Exactly the same problem for me, I have a 2007 Focus Titanium and I need to check my power outlet fuse.
I have tried to get onto the Etis Ford site but it doesn't seem to be working.
Is there any development on this? Anyone have a fuse diagram for the box shown in the picture?
Thanks
Old Jul 1, 2009 | 02:54 PM
Island Lad's Avatar
Island Lad
hope it helps.
Hi there B19 JUB,
I have tried opening the photo but cannot. I think I have the same issue of different layout in the manual to the actual fuse box. ETIS, I can't get into, so is there any other way of getting hold of the layout for mine. I have a Focus 1.8TDi 07 plate.
Thanks,
Island Lad
Old Jul 4, 2009 | 05:16 PM
Casey12a's Avatar
Casey12a
Hi All,
I have the same problem as I need to replace the fuse for my cigarette lighter. Can somebody please let me know which number fuse it is?
Thanks.
Old Jul 22, 2009 | 12:41 PM
ford2me's Avatar
ford2me
>>Post by Casey12a
>>I have the same problem as I need to replace the fuse for my cigarette >>lighter. Can somebody please let me know which number fuse it is?
Referring to pasted picture from djsri, this is similar to my Ford Focus LX 2005 Reg Auto, manual booklet (pages 153-154) with the following slots numbering.
top row (6 fuse slots) - number 37 to 42
second row (22 fuse slots) - number 43 to 64
third row (22 fuse slots) - 65 to 86
Cigarette fuse is situated on fuse number 39, a 20amp, yellow colour.
Though I have not done mending one as I am not an expert, just wondering though as precaution, has anyone done this before. Any how-to steps including precautionary? Again, this i believe is just query of a precautionary being a non-expert.
rds.
Old Nov 2, 2009 | 10:25 PM
andy2002's Avatar
andy2002
Hi
I'm also trying to find a fuse in my focus zetec (2005) but have the same problem where the diagram in the manual doesn't match with the fusebox in my car. The fusebox I have has:
could anybody tell me where the daytime running lights fuse is?? or does anybody have a diagram i could look at? im planning on wiring in another cigarette socket (behind the dash) so i can hardwire my satnav power in behind the dash (i believe the daytime running lights power supply is ignition switched and not currently used...but cant find it!!).
Thanks in advance
Old Dec 28, 2010 | 04:23 PM
anilbagga's Avatar
anilbagga
Hi,
I have a 2007 plate mk II Focus as well and as the others have stated the fuse box layout inside the car (underneath the glove box) does not bear any relation to the one shown in the Ford manual. I have a cigarette lighter fuse that has gone and the Ford manual indicates fuse 39, however my fuse box has numbers that start in the hundreds. Does anyone know where the fuse is for a 2007 Mk II Ford Focus?
Many thanks
Old Dec 29, 2010 | 01:50 PM
mikerichards's Avatar
mikerichards
Originally Posted by anilbagga
Hi,
Many thanks
I have an 07 Focus just bought and the manual shows fuses inside the car from 100 up while the actual fuse box has 37-86. I've just successfully replaced no 39 and got the cigarette lighter outlet working. My manual says the power outlet is on no F109 so you should probably try that first.
Old Dec 29, 2010 | 03:21 PM
anilbagga's Avatar
anilbagga
Mike, Many thanks I will try F109 1st and will let you know the outcome.
Old Oct 16, 2012 | 12:52 PM
moty147's Avatar
moty147
Default I have same issue
Hello,
Can anyone help me also?
I am looking for the fuse that is for the rear licence plate lights?
Thanks in advance
Old Nov 21, 2012 | 05:16 PM
studdart76's Avatar
studdart76
Originally Posted by ford2me
>>Post by Casey12a
rds.
a know this is an old thread but i could really do with the list for the above fuse panel..as my car is 2007 thats when it changed model and ive somehow got the new model manual i need the old one as above.
thank you
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
