rs2000 exhaust manifold
No, The 2wd and 4wd exhaust manifolds are not the same, there is an extra knik in the 4wd manifold. If your looking for a manifold try www.rs2000-16v.com, you rarely see them on ebay. before fitting get the EPS pipes removed and get the internal welds replaced with external welds and the internal ones ground out. This will help the engine brether better and release a few extra horses.
ah bugger i can get a 2wd one right away shame it wont fit tho!
i'll check the site too cheers..
caprixpack
Sep 25, 2015 07:53 PM
