Battery Light Help Please
Hi
My battery light is on when my car lights and gauges are on. The gauges illuminate more when I put my wipers on etc.
Has anyone got any ideas why this is happening and what I can do to sort it please.
Sounds like the alternator Has packed up, you need to check the voltage across the battery with the engine running, should be at least 13 volts plus
i have just charged the alternator belt and i have a volt gauge in car and it reads just 13 volts with the lights on and my gauges lights on but the battary light is still on the dash
I replaced my battery thinking it was shot, as mine was doing a similar thing to yours. Everytime I get the windows right to the top, the battery light glows on the dash. Just old wiring i reckon, somewhere along the line.
probably old wiring loom.
mine does the whole dim glow when using the electric windows etc, and thats with a brand new alternator, oversized battery and fresh connectors where it needs.
so long as the electrics work, the car isn't miss firing, and it starts! s'all good =]
155lee
Sep 6, 2016 11:10 AM
