rs2000 converison??
Old Jan 20, 2009 | 07:39 PM
pobrs's Avatar
pobrs
Default rs2000 converison??
hey, does anyone know if its possible to install a mk5/6 escort rs2000 engine into a series 2 rs turbo/ xr3i, and if so how?
Old Jan 20, 2009 | 07:44 PM
Mark_'s Avatar
Mark_
it is but its easier to do on a mk3 escort, on the mk4 you need to space the subframe with washers alittle and modify the drivers suspension turret to get clearence, the one ive seen was tapped with a hammer,
Old Jan 20, 2009 | 07:51 PM
pobrs's Avatar
pobrs
cheers thanks.
Old Jan 20, 2009 | 09:14 PM
studabear's Avatar
studabear
a lot of people on here will say use a 2.0 zetec instead
Old Jan 22, 2009 | 07:16 PM
koskar's Avatar
koskar
I didn't modify turret on my setup. Only modified part of engine mountings was this: . More pics (some old in folders) here: http://s200.photobucket.com/albums/a...000/?start=all
Old Jan 22, 2009 | 07:22 PM
naskoto_'s Avatar
naskoto_
does rs2k MTX75 box fit to mk4 escort?
Old Jan 22, 2009 | 07:24 PM
Mark_'s Avatar
Mark_
ok cool, the guy who's one i see is a user on here his username is fonfe he had to modify turret
Old Feb 20, 2009 | 09:14 PM
fonfe's Avatar
fonfe
thatl be me then lol
yeah i cut the whole mounting plate off and then made one up to suit using the original rs2k mount as my cvh one cracked when i was only using the zetec, i also did it so that i could lower the engine so not to cut a hole in the bonnet, so the gearbox and engine are about 10-20mm lower but ive got an rst bonnet with the vent covers so one cover has rubbed a tiny tiny bit on chaincover but will be fine if you dont use a plate.
its not an easy fit, only have space for my pinky finger between the lower pulley and inner wing so its a up from underneath job i felt but id use a ramp if you can as it makes life so much easier as i had to dummy fit it several time to get it right.
ive just bought a 2.3 though with the intention of building a 2.3 hybrid using the rs parts but have decided to turbo it instead to do something different.
drop me a pm if you got any more questions fella. do check out koska's pics though as they are quite good, ive got a load of it going in but dont know how to make my album open for anyone to see im afriad.
Old Mar 3, 2009 | 09:51 AM
koskar's Avatar
koskar
I just fitted my engine to another chassy and I take some new pics.
What you would see on gearbox end
and timing chain end
Old Mar 3, 2009 | 11:32 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
im in the process of fitting one of these engines in a MK1 fez,u think urs is tight,lol
Old Mar 4, 2009 | 07:47 PM
studabear's Avatar
studabear
u doin a resto thread for it?
Old Mar 4, 2009 | 08:27 PM
orion_crazy_carl
orion=mini saff
got millions of piccys sure will do wen its a bit further along!!got it in place today,so were pretty happy!!
Old Mar 4, 2009 | 09:21 PM
orion_crazy_carl
orion=mini saff
heres a couple of pics of today
Old Jul 13, 2009 | 07:32 PM
fonfe123's Avatar
fonfe123
christ now that IS TIGHT!
Old Jul 14, 2009 | 06:07 AM
jonny s2's Avatar
jonny s2
interesting conversion for sure,but is too heavy and costs far too much to tune an get very little power from,just use a cvh or zetec far cheaper much lighter and more power
Old Jul 14, 2009 | 04:38 PM
orion_crazy_carl
orion=mini saff
tight as a nun who cares about weight, tuning, its just a little different from the norm, and 150 bhp in a stripped out mk1 fez, i think it will be quick enuff
Old Aug 31, 2009 | 06:07 PM
fonfe123's Avatar
fonfe123
2.3 hybrid is a cheap conversion if everything is setup to use the rs2k lump. will give loads of torque and around the 170-180 figure running on the OE system. for best results something like a unichip should be used
Old Aug 31, 2009 | 11:52 PM
James213's Avatar
James213
Seen a MK3 fieasta RS 1800 with an RS2000 engine and it went like fook sounded well too
Pwrs2k
120
Oct 16, 2015 03:16 PM
Fordmad!
15
Sep 27, 2015 06:24 PM
Thrush
Sep 1, 2004 08:24 PM
RS2000CUSTOM
Shows & Track Days
Jun 17, 2004 09:45 PM
