balieys brether fittin prob
im after so info pics may or a fitted baileys brether plz i have 1 with not all pipes i belive
on the breether tank it has 4 pipes and im un suer where they go
2 on the bottom 1 bigger than the other and 2 on top the same size any help would be grate
does the bigger bottom 1 go in the bottom of the block ?
top 1 at the back goes onto your rocker cover, 1 next to it goes to the flame trap. the lower 1 goes under the manifold into the block and the very bottom 1 vents fumes away.
can get you some pics tomorrow if you need them
Originally Posted by Dilly
thought one returned to the sump via an adapter that goes onto sump plug?
get an adaptor fabricated with a pipe fitting on top.
Originally Posted by bigal1978
where would i get fittin kit plz as all i have is the metal useless tub and 2 hoses
Can't remember how much,you get 4 pipes,all the hose-clips,adapter for cam cover and block,small plastic bung to block inlet pipe.
H i guys i have just taken one off my
500, to put it back to standard and havn,t
a clue it was originally can any one help??
i have removed the tank and got new
rocker cover to replace the one with
pipe fitting, but what about the other pipe
fittings???
cheers A NOVICE MECHANIC.
fittings???
CabrioTurbo
Aug 1, 2015 11:04 AM
