Focus Tdci
Old Jan 20, 2009 | 04:12 PM
Maltese Andy's Avatar
Maltese Andy
Unhappy Focus Tdci
Hi guys,
I'm planning on buying a Mk1 Focus Face lift model, diesel but I don't know much about them
Any help would be much appreciated
A few questions
What is the difference between the 100bhp and 115bhp Tdci engines? is it only the ECU?
Can the 100bhp version be upgraded to 115 by simply replacing the ECU?
Which model has rear disc brakes?
The 1.8Tdci engine is belt driven and 8 valves not 16 right?
Any comments on this engine? What should I look out for?
How does the Tdci compare to the Tddi? Which is better?
Sorry for all the questions and thanks form beforehand to anyone who could answer any of these questions
Regards
Andrew
Andrew
Old Jan 24, 2009 | 07:48 AM
Gazeddy's Avatar
Gazeddy
This is something im looking at at work with a mate everything looks the same. it does seem to be all in the ecu
not as simple you need to take the 115 programming and put it on the original 100 ecu #
the 115 bhp one would but it maye depend on trim spec
right
tdci is better. tddi is mechanical fuel distrobution whereas tdci is common rail electronic injector control
Old Jan 27, 2009 | 06:55 PM
Maltese Andy
Red face
Thyanks Gaz,
Very informative.
The programming part sounds a bit complicated.
I would obviously go for the 115 and avoid the trouble but the road tax is about Ł40 cheaper per year for the 100 here in Malta. If it was as simple as replacing the Ecu it would be quite tempting.
Regarding the number of valves,
I have an Autodata cd rom with all the data of most cars.
When I looked up Ford Focus or Transit Connect, there were 3 types of engines.
a) 1.8 Tddi
b)1.8 Tdci
c)18d
When I looked up the 3rd one and looked up 'timing belt renewal' the diagram showed 2 camshaft pulleys (DOHC) and this type of engine is chain driven not belt.
Has anyone ever heard of this engine? The program gave me all the data on this engine so it must exist but I've never seen it on a Focus or Connect.
Old Jan 27, 2009 | 07:51 PM
focusv8's Avatar
focusv8
The 1.8D is the old non turbo engine used in Escorts and Fiesta but that was belt not chain.
Tddi is a poor performer compared to Tdci.
Old Jan 27, 2009 | 08:13 PM
Gazeddy's Avatar
Gazeddy
the programming thing is easy enogh if you know your way round the diagnostics gear. i will find out if you can just swap the ecu's over. i dont think youcan as they are linked to the pats
Old Jan 27, 2009 | 08:14 PM
Gazeddy's Avatar
Gazeddy
i dont know of a ford diesel in 1800 with twin cams n chain
and the tddi and tdci are pretty much the same engine as ford have used for years in their diesels
Old Jan 28, 2009 | 09:31 PM
Maltese Andy
Cool
Sorry,
my mistake,
was actually a 2.4 Transit Tdci engine I was looking at.
I asked about the ECU because it is quite a similar story with the Fiesta RS1800
the XR2 is 105bhp and the RS is 130. The main difference is the Ecu, cam profile and trottle body diameter.
Would be nice to know whats different on the diesels.
Regarding the car itself (and the engine), I'm planning on buying one with under 100k miles and then drive it down to Malta, which is about 1600 miles away.
What are the major faults in the Focus?
cheeRS
Old Jan 31, 2009 | 07:51 AM
Gazeddy's Avatar
Gazeddy
the ecu swap is as i thought cant be straight swpaaed without initiallizing the pats for your key/s
tdci look for pump front seals dmf injectors
thats about it
Old Feb 2, 2009 | 08:33 PM
1939's Avatar
1939
Default mk1 focus tdi
hi every one wonder is any one would no is there an eltric fuel pump in the fuel tank of a mk1 ford focus thank for any help that any one can help me out
Old Feb 2, 2009 | 08:38 PM
1939's Avatar
1939
[quote=1939;3921460]hi every one wonder is any one would no is there an eltric fuel pump in the fuel tank of a mk1 ford focus thank you for any help that any one can help me out[/
Old Feb 10, 2009 | 09:20 AM
Weegi's Avatar
Weegi
Used to have a focus tdci sport brilliant car lovely drive and very comfortable ride, and was pretty quick
tankybaby66
Feb 6, 2016 02:24 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
