help wiring problems!!!
I need to find somewhere i can find wiring diagrams for the following,
1, dashboard wiring for a mrk 5 fiesta/puma without aircon.!!
2, S2 rs turbo engine wiring loom
if anyone could help or give me an idea on where to find them woud be fantastic..
well the mk5 wiring loom you should be able to find in a haynes manual and if you go on there website you might still be able to get the s2 manual as well, they will be your best option because i guess you putting a s2 engine into a mk5 fez and the hole load of diagram's will let you deter where the wires are all going after the engine bay/dash and through the car and clear up any loose wires you might have
The Enigma
Sep 12, 2015 10:12 PM
Si B
Sep 12, 2015 06:49 AM
