best aftermarket management for fiesta rs turbo??
as title really looking at changing management on my frst.
look at stu's chips and also omex ecu.
what are your views and opinions on these or any suggestions?
thanks kurt
thanks kurt
My brother has just opted to use GoTech's EFi ECU for his big power CVH. Can't comment on how good it is as it's still in the box while he does some more of the ground work in preperation
Neil and a few others at Fast Ford have used emerald to good effect, but as said whatever tuner/mapper you use needs to be comfy with the stuff.
The mapping on emerald is so simple, nothing special required at all, all on disc you get with it.
paceo
Feb 3, 2016 10:31 AM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
