cosworth new bits and used bits,calipers,poly bush kit
got a few new and used cosworth parts that i have collected and are now taking up room.
used sierra cosworth fuel pump with 12cm of wire(pos and neg).i upgraded to an 044 so this is spare,quiet and in good condition.£20.
2wd sapphire rear beam and suspension arms,bare.i bought an adjustable rear beam 2nd hand so this is spare.£50
2wd 4 pot front calipers and rear calipers,they were ok for the mot on brake effiency but with the car sitting around i think the 2 inner pots on both calipers are a bit sticky and the rears are in good working order(non vented).£50 for all 4
4x4 sapphire cosworth cambelt cover,in good used condition,bottom pulley has been rubbing on it but not noticeable when fitted,where the 2 bolts go through the top 1 part cas a split up it,not noticeable when the bolt and washer are fitted,£25
1 brand new 2wd air filter to turbo blue samco hose.£25
i brand new air filter to t34 turbo samco hose,i cut it down to make it fit better so the bend is closer to the turbo and not kinked.£15
1 2wd/4x4 ramair air filter,1000 miles.like new still.£20
i set of cosworth head bolts,standard ford,new in bag.they are like a torq headed bolt but with more grooves for the tool you would use to tighten them.£12
i powerflex polybush kit.used but only done 1000 miles max.consists of,inner and outer tca bushes,front arb bushes,rear beam bushes,rear swinging arm inner and outer bushes.im keeping the rear arb bushes and the front top mount bushes.you can buy these easily off of ebay,they cost me £270 a year ago and i would take £110.i have upgraded to rose joints and compression struts.these are the proper bushes and not the mickey mouse cheap ones you see.
postage is no problem on all of the above.pm me instead of posting up as it keeps the thread easy to read.thanks,lee
2wd 4 pot front calipers and rear calipers,i brand new air filter to t34 turbo samco hose,i cut it down to make it fit better so the bend is closer to the turbo and not kinked.£15
i will take these mate whats your paypal
hi,the air filter is away sorry,the polybush kit is for a 2wd sapphire cosworth,ive ended up keeping some of the bushes as im not using adjustable compression struts but i do have the following spare.rear trailing arms inner and outer bushes,front tca inner bushes.all the expensive powerflex bushes.thanks,lee
Wilsfoci
15
Mar 30, 2016 10:26 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
