its not uncommon for the heater elements to break, as above check for power and check earth strap...ive had a screen not work on a f reg orion and it turned out to be the relay..it had a timer on it that turned itself off after a set time..it kept turning itself off soon as i switched it on
assuming that the wiring is the same as my orion it was a yellow relay in the fuse box..iirc it was marked on the cover...i would try a continuity check on the screen first to make sure the screen isnt fubar..
yer i'll give that i go, if its the screen i may get another cos there so handy over winter
