Anyone doing or done an underside resto on a S2 ???
Im in the process of doing mine just wanted peoples opinions on how easy/hard parts are to come by, or what parts people found hard to remove etc. What colours are people doing fuel tanks, tank straps, rear arms etc. Have people put new poly bushes in or new standard bushes ??
i found most things easy to come by this site and ebay helped
im doing a mk4 cabby in gray and had all the arms and hubs done sliver and black
aint got a fuel tank yet and i fitted poly bushes
ive also binned the tie bars in this pic aswell ive got adjustable ones now
i did mine car. I painted the underside red and all the parts black, but the fueltank silver and the koni's stayed yellow. I did alot with hamerite and normal spraycans, but if i could do it over i would poudercoat alot parts. I had some things with fuel and laying on the ground andso they damage. not much, but if you look at the costs of all the spraycans it both costs alot
I like the silver rear arms, my rear ARB has been painted black, just deciding on what colour to paint the parts all black or silver and black
The best thing on my opinion is to keep the colours standard.
Tank-silver
suspension-black
fuel pipes-green e.c.t.
Also polybush every thing.Then you never need worry and it looks good
Here's mine.
Tank-silver
suspension-black
Here's mine.
Not as nice/concourse as the others here, just wanted mine to look tidy.
Fuel pump hanger will more than likely be rotton beyond repair, I'd polybush and replace all the bolts.
I kept standard colours but a touch of colour for the tie bars.
few pics of whats been thrown back on mine already, just black stonechipped underside, then black powdercoated arms/tie bars/hubs etc, and all new genuine ford nuts bolts and washers
Ive been taking some pics of mine, alot of time and effort has gone into some of the cars shown in this thread and id be a happy man if mine looked half as good as the ones shown.
if i understand you correct you mean the fuel pipe from the chassis? if so there is a screw in it
If you mean the fillerneck from the fuel tank it is just pushed in you can pull it out
and i you don't mean both of these i look stupid and i need to work on my english then
anodised ive undone the screw next to the cap, no rust, around the cap, im hoping its just the sealent cracking around the filler neck (inside the arch where the pipes come down)
think i remember from his resto thread that he used the mega expensive 3M bag type stonechip underseal stuff, that comes in the dark grey, very close to mercury grey
its 1 of the nicest underside restos iv seen on a car that wasnt spending its life in a carcoon, subtle and clean as fook
As RSANDY said.(Kind words)I used the 3m bag sealer then painted it with HAMMERTITE HAMMERED GREY.The closest to mercury grey.
Bag sealer = £110
Hammerite = £15.
Poly bushes = £210
Powder coated suspension = £250
All new bolts,nuts and washers = £45
It,s not cheap doing an underbody resto,but do it right and it will last a good 10 years.
Well worth it for the way it looks and peace of mind.
No more crossing your fingers come m.o.t time.
Bag sealer = £110
Hammerite = £15.
Poly bushes = £210
applies to prepping anything before paint...
flat using suitable grade wet n dry, wipe with panel degreaser, tackrag, then paint
on a tank though, especially if u say its ready for paint, id ignore the wet n dry n give it a quick rub with red scotch, then degreser and tack rag
yeah as above, if its bare metal, grind or red scotch it perfectly clean (depending how much surface rust has managed to form), and then etch primer it, so it has a well bonded primer base
when you said ready for paint, i assumed it was already in primer, my mistake
that's also what i did with my petrol tank.
but for the underside i used also a sealend for the places where they also sprayed it as factory, because not the whole underside has been sprayed in the factory. Just the chassisrails and wheelarches and besides the skirts a little bit. That's whats done on my car and all the rest is just painted. Factory was only primer, but i wasn't happy with that so i did everyting with red.
Bag sealer = £110
Hammerite = £15.
Poly bushes = £210
Bag sealer = £110
Hammerite = £15.
Poly bushes = £210
cool hammerd grey it is then lol
