alternator power question
Old Dec 28, 2008 | 08:37 PM
dom123's Avatar
dom123
Default alternator power question
my escos has 13.8v on idle if i switch everything on and mean everything rad fans as well, both headed screens...etc... the voltage drops to 11.8 does this mean my alternators hadit underload??
cheers
Old Dec 28, 2008 | 08:38 PM
LHD220Turbo's Avatar
LHD220Turbo
you need to test at around 2000rpm, not idle
you need to be seeing around 14v + ideally
Old Dec 28, 2008 | 08:42 PM
105epwr's Avatar
105epwr
you want over 12v really at idle,disconnect your battery and see what the battery is on its own without the alternator or running that wants to be a tad over 12v alone.
Old Dec 28, 2008 | 08:47 PM
westus1's Avatar
westus1
it should never go under 12v even at idle
check the fan belt is right tight
if it is then looks like alt has seen better days
Old Dec 28, 2008 | 08:50 PM
dom123's Avatar
dom123
sos forgot to mention i did try it at 3000rpm, the belt has its own spring loaded tentioner so it cant be lose... where a cheap place to get a replacement? Camberly Autos?
Old Dec 28, 2008 | 08:56 PM
westus1's Avatar
westus1
thats what i get for for not reading it correctly, just realised you said escos so belt is self tensioning( for me)
dont know who's best for yo local mate i'm in glasgow
just shop around, wont be that dear they're very simple alternators
Old Dec 29, 2008 | 07:02 AM
Does the situation ever occur where you have everything on at idle ?
I suspect the answer is NO, there is nothing wrong with this alternator, they cannot do mega loads at idle speed, simple as that, doesn't cause a problem as they don't do it in use anyway.
Do the test at 2000rpm, with a FULLY charged battery and so long as over around 12.2/12.4 stop worrying, is the alternator singing, as they willoften do this when overloaded.
The 90 amp(or whatever) is a peak reading, realistically the peak is a normal continuous max output.
jonfoc
16
Sep 11, 2018 05:35 PM
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
